MAX36051 Ultra-low-power secur
新品快讯
30人已加入
The MAX36051 is ideal for applications where security and low power are especially critical.
Security manager with secure memory and tamper resistance draws low power.
SUNNYVALE, CA—July 6, 2010—Maxim Integrated Products (NASDAQ: MXIM) introduces the MAX36051 security manager. The device provides 128 bytes of nonimprinting memory to securely store sensitive data, while drawing very little battery power in standby mode (1.5µA). The internal tamper monitors and tamper detection inputs interface with external sensors so that the end user has a greater level of security in their system. With ultra-low power consumption, this device is ideal in devices where small-capacity batteries are used. The MAX36051 is most appropriate for applications where tamper detection and secure data storage are required and low power consumption is critical, as in secure USB, power meter, and point-of-sale (POS) applications.
The MAX36051 is an ultra-low-power device that provides tamper detection regardless of the power source. The on-chip, battery-backup controller function constantly monitors main power (VCC) and automatically switches to the battery (VBAT) when the main power is too low or not present at all. For battery-power conservation, this security manager has various duty-cycle options that facilitate its low current consumption. Drawing a minimum of 1.5µA of battery current, the device can retain critical information and monitor tampers while on battery power alone.
The MAX36051 is fully specified over the -40°C to +85°C extended temperature range. It is available in a 4mm x 4mm, lead-free, 16-ball CSBGA package. Pricing is available under mutual NDA.
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6300 products serving the industrial, communications, consumer, and computing markets.
