基于TDA5051A设计的家庭自动化调制解调技术
模拟技术
2532人已加入
本文介绍了TDA5051A主要特性和优势,方框图,多种应用电路和测量电路。TDA5051A是NXP 公司的家庭自动化调制解调器,单电源5V工作,数据速率600波特或1200波特,特别适用于ASK发送。TDA5051A具有全数字载波发生和整形,输出功率级具有过载保护,接收输入有自动增益控制(AGC),8位ADC和窄带数字滤波,容易和EN50065-1兼容网络兼容,主要用在家用电器控制,能量/热量控制,采用家庭电力网络的ASK数据发送。
TDA5051A:Home automation modem
The TDA5051A is a modem IC, specifically dedicated to ASK transmission by means of the home power supply network, at 600 baud or 1200 baud data rate. It operates from a single 5 V supply.
TDA5051A 主要特性和优势:
Full digital carrier generation and shaping
Modulation/demodulation frequency set by clock adjustment, from microcontroller or
on-chip oscillator
High clock rate of 6-bit D/A (Digital to Analog) converter for rejection of aliasing
components
Fully integrated output power stage with overload protection
Automatic Gain Control (AGC) at receiver input
8-bit A/D (Analog to Digital) converter and narrow digital filtering
Digital demodulation delivering baseband data
Easy compliance with EN50065-1 with simple coupling network
Few external components for low cost applications
SO16 plastic package
TDA5051A应用:
Home appliance control (air conditioning, shutters, lighting, alarms and so on)
Energy/heating control
Amplitude Shift Keying (ASK) data transmission using the home power network
TDA5051A
图1。TDA5051A方框图
TDA5051A
图2。TDA5051A片上时钟电路典型配置图
TDA5051A
图3。动力线不绝缘TDA5051A应用框图
TDA5051A
图4。动力线绝缘TDA5051A应用框图
TDA5051A
图5。动力线不绝缘TDA5051A应用框图,提升了灵敏度(典型值68dBuV)
TDA5051A
图6。动力线绝缘TDA5051A应用框图,提升了灵敏度(典型值68dBuV)
TDA5051A
图7。测量THD和TX OUT信号带宽的电路图
TDA5051A
图8。测量误码率(BER)的电路图
