基于UBA2028设计的600V荧光灯电源技术
电源设计应用
455人已加入
The UBA2028 is a high voltage power IC that drives and controls electronically ballasted
Compact Fluorescent Lamps (CFLs). The IC includes a Metal-Oxide-Semiconductor
Transistor (MOST) half-bridge power circuit, a dimming function, a high voltage level shift
circuit, an oscillator function, a lamp voltage monitor, a current control function, a timer
function and various protections.
UBA2028主要特性和优势:
􀂄 Two internal 600 V, 3 Ω max MOST half-bridge power circuits
􀂄 For steady state currents up to 280 mA
􀂄 For ignition currents up to 1.5 A
􀂄 Adjustable preheat time
􀂄 Adjustable preheat current
􀂄 Current controlled operating
􀂄 Single ignition attempt
􀂄 Adaptive non-overlap time control
􀂄 Integrated high voltage level shift function
􀂄 Power-down function
􀂄 Protection against lamp failures or lamp removal
􀂄 Capacitive mode protection
UBA2028应用:
􀂄 5 W to 25 W dimmable CFLs, provided that the maximum junction temperature is not
exceeded.
荧光
图1.UBA2028方框图
荧光
图2.UBA2028 的PGND 和GND连接图
荧光
图3.UBA2028 120V的应用电路图
荧光
图4.UBA2028 230V的应用电路图
