基于NCP4303设计的高效开关电源技术
电源设计应用
456人已加入
本文介绍了NCP4303主要特性,方框图,ZCD检测电路框图以及LLC转换器,DCM或QR反激转换器与在宽频LLC应用的电路。
NCP4303是On Semi 公司的次级同步整流驱动器,是高效开关电源(SMPS)解决方案。NCP4303具有阈值可调的精密的次级零电流检测,工作模式包括CCM,DCM和QR反激拓扑。工作电压高达30V,具有5A/2.5A峰值沉/源驱动能力,典型应用包括笔记本电脑适配器,大功率密度的AC/DC电源,游戏机和所有高效开关电源。
NCP4303主要特性
Self−Contained Control of Synchronous Rectifier in CCM, DCM, and QR Flyback Applications
Precise True Secondary Zero Current Detection with Adjustable Threshold
Automatic Parasitic Inductance Compensation Input
Typically 40 ns Turn off Delay from Current Sense Input to Driver
Zero Current Detection Pin Capability up to 200 V
Ultrafast Trigger Interface to External Signal for CCM operation
Disable Input to Enter Standby or Low Consumption Mode
Adjustable Minimum On Time Independent of VCC Level
Adjustable Minimum Off Time Independent of VCC Level
5 A / 2.5 A Peak Current Sink / Source Drive Capability
Operating Voltage Range up to 30 V
Gate Drive Clamp of Either 12 V (NCP4303A) or 6 V (NCP4303B)
Low Startup and Standby Current Consumption
Maximum Frequency of Operation up to 500 kHz
SOIC−8 Package
These are Pb−Free Devices
NCP4303典型应用:
Notebook Adapters
High Power Density AC/DC Power Supplies
Gaming Consoles
All SMPS with High Efficiency Requirements
电源
图1。NCP4303方框图
电源
图2。NCP4303 ZCD检测电路框图
电源
图3。NCP4303典型应用案例:LLC转换器
电源
图4。NCP4303典型应用案例:DCM或QR反激转换器
电源
图5。NCP4303在CCM反激转换器的应用电路图
电源
图6。NCP4303在宽频LLC应用的电路图
