FDTD参数选择估计程序
编程实验
72人已加入
  针对二阶精度的时域有限差分程序.
  现可直接调用的源信号是:一个周期的正弦信号,高期脉冲,ricker子波.
  其它信号可手动修改源信号接口,或源生成函数.
  请函数.
  % 1. determine maximum possible spatial field discretization.
  % (in order to avoid numerical dispersion).(5 grid points per
  % minimum wavelength are needed to avoid dispersion).
  % 2. find the maximum possible time step using this dx and dz.
  % (in order to avoid numerical instability).
  % Coded by yiling. Email: yiling@email.jlu.edu.cn
  % Date: 2008
  clear;
  clc;
  dx=0.02; % (m)
  dy=0.02; % (m)
  epsilonmax=25; % \Epsion. maximum relative dielectric permittivity.
  mumax=1; % \Mu. maximum relative magnetic permeability.
  sourcetype='ricker'; % can be 'cont_sine', 'gaussian', 'ricker'.
  freq=100e6; % (Hz)
  amp=1; % amplitude.
  thres=0.02; % threshold to determine maximum frequency in source pulse.(proposed = 0.02).
  Timewindows=528; % (ns)
  vlight=0.3;
  epsilonmin=1; % \Epsion. minimum relative dielectric permittivity.
  mumin=1; % \Mu. minimum relative magnetic permeability.
  dt=1/(vlight*sqrt(1/dx^2+1/dy^2));
  % minwavelength=vlight/sqrt(epsilinmax);
  t=0:dt:Timewindows;
  dt=dt*1e-9;
  t=t*1e-9;
  Timewindows=Timewindows*1e-9;
  source=gprmaxso(sourcetype,amp,freq,dt,Timewindows);
  [dxmax,wlmin,fmax] = finddx(epsilonmax,mumax,source,t,thres);
  disp('----------------------------------------------------------------- ');
  disp(['Maximum frequency contained in source pulse = ',num2str(fmax/1e6),' MHz']);
  disp(['Minimum wavelength in simulation grid = ',num2str(wlmin),' m']);
  disp(['Maximum possible electric/magnetic field discretization (dx,dy) = ',num2str(dxmax),' m']);
  disp(' ');
  dtmax = finddt(epsilonmin,mumin,dxmax,dxmax);
  disp(['Maximum possible time step with this discretization = ',num2str(dtmax/1e-9),' ns']);
  子函数1
  function dtmax = finddt(epmin,mumin,dx,dz);
  % finddt.m
  % This function finds the maximum time step that can be used in the 2-D
  % FDTD modeling codes TM_model2d.m and TE_model2d.m, such that they remain
  % numerically stable. Second-order-accurate time and fourth-order-accurate
  % spatial derivatives are assumed (i.e., O(2,4)).
  % Syntax: dtmax = finddt(epmin,mumin,dx,dz)
  % where dtmax = maximum time step for FDTD to be stable
  % epmin = minimum relative dielectric permittivity in grid
  % mumin = minimum relative magnetic permeability in grid
  % dx = spatial discretization in x-direction (m)
  % dz = spatial discretization in z-direction (m)
  % by James Irving
  % July 2005
  % convert relative permittivity and permeability to true values
  mu0 = 1.2566370614e-6;
  ep0 = 8.8541878176e-12;
  epmin = epmin*ep0;
  mumin = mumin*mu0;
  % determine maximum allowable time step for numerical stability
  dtmax = 6/7*sqrt(epmin*mumin/(1/dx^2 + 1/dz^2));
  子函数2
  function [dxmax,wlmin,fmax] = finddx(epmax,mumax,srcpulse,t,thres);
  % finddx.m
  % This function finds the maximum spatial discretization that can be used in the
  % 2-D FDTD modeling codes TM_model2d.m and TE_model2d.m, such that numerical
  % dispersion is avoided. Second-order accurate time and fourth-order-accurate
  % spatial derivatives are assumed (i.e., O(2,4)). Consequently, 5 field points
  % per minimum wavelength are required.
  % Note: The dx value obtained with this program is needed to compute the maximum
  % time step (dt) that can be used to avoid numerical instability. However, the
  % time vector and source pulse are required in this code to determine the highest
  % frequency component in the source pulse. For this program, make sure to use a fine
  % temporal discretization for the source pulse, such that no frequency components
  % present in the pulse are aliased.
  % Syntax: [dx,wlmin,fmax] = finddx(epmax,mumax,srcpulse,t,thres)
  % where dxmax = maximum spatial discretization possible (m)
  % wlmin = minimum wavelength in the model (m)
  % fmax = maximum frequency contained in source pulse (Hz)
  % epmax = maximum relative dielectric permittivity in grid
  % mumax = maximum relative magnetic permeability in grid
  % srcpulse = source pulse for FDTD simulation
  % t = associated time vector (s)
  % thres = threshold to determine maximum frequency in source pulse
  % (default = 0.02)
  % by James Irving
  % July 2005
  if nargin==4; thres=0.02; end
  epmax = epmax*ep0;
  mumax = mumax*mu0;
  % compute amplitude spectrum of source pulse and corresponding frequency vector
  n = 2^nextpow2(length(srcpulse));
  W = abs(fftshift(fft(srcpulse,n)));
  W = W./max(W);
  fn = 0.5/(t(2)-t(1));
  df = 2.*fn/n;
  f = -fn:df:fn-df;
  W = W(n/2+1:end);
  f = f(n/2+1:end);
  % determine the maximum allowable spatial disretization
  % (5 grid points per minimum wavelength are needed to avoid dispersion)
  fmax = f(max(find(W>=thres)));
  wlmin = 1/(fmax*sqrt(epmax*mumax));
  dxmax = wlmin/5;
  子函数3
  function [excitation]=gprmaxso(type,amp,freq,dt,total_time);
  % GPRMAXSO Computes the excitation function used in 'GprMax2D/3D'
  % simulators for ground probing radar.
  % [excitation] = gprmaxso('source_type',Amplitude,frequency,Time_step,Time_window)
  % source_type can be 'cont_sine', 'gaussian', 'ricker'
  % Amplitude is the amplitude of the source
  % frequency is the frequency of the source in Hz
  % Time_step is the time step in seconds
  % Time_window is the total simulated time in seconds
  % excitation is a vector which contains the excitation function.
  % If you type plot(excitation) Matlab will plot it.
  % You can use the signal processing capabilities of Matlab
  % to get a Spectrum etc.
  % Copyright: Antonis Giannopoulos, 2002 This file can be distributed freely.
  RAMPD=0.25;
  if(nargin < 5)
  error('GPRMAXSO requires all five arguments ');
  end;
  if(isstr(type)~=1)
  error('First argument should be a source type');
  end;
  if(freq==0)
  error(['Frequency is zero']);
  end;
  iter=total_time/dt;
  time=0;
  if(strcmp(type,'ricker')==1)
  rickth=2.0*pi*pi*freq*freq;
  rickper=1.0/freq;
  ricksc=sqrt(exp(1.0)/(2.0*rickth));
  i=1;
  while(time<=total_time)
  delay=(time-rickper);
  temp=exp(-rickth*delay*delay);
  excitation(i)=ricksc*temp*(-2.0)*rickth*delay;
  time=time+dt;
  i=i+1;
  end;
  end;
  if(strcmp(type,'gaussian')==1)
  rickper=1.0/freq;
  i=1;
  excitation(i)=exp((-rickth)*delay*delay);
  time=time+dt;
  i=i+1;
  end;
  end;
  if(strcmp(type,'cont_sine')==1)
  i=1;
  ramp=time*RAMPD*freq;
  if(ramp>1.0)
  ramp=1.0;
  end;
  excitation(i)=ramp*sin(2.0*pi*freq*time);
  time=time+dt;
  i=i+1;
  end;
  end;
  if(strcmp(type,'sine')==1)
  i=1;
  excitation(i)=sin(2.0*pi*freq*time);
  if(time*freq>1.0)
  excitation(i)=0.0;
  end;
  time=time+dt;
  i=i+1;
  end;
  end;
  excitation=excitation.*amp;
  • 相关推荐
  • 热点推荐
  • FDTD
