ICL8001G是Infineon公司的准谐振模式
LED驱动器,精密的PWM可用于相位调光,功率因素大于98%,效率高达90%,工作电压高达26V。本文介绍了ICL8001G主要特性和亮点,方框图以及初级控制应用电路图和EVAL-LED-ICL8001G-Bulb02演示板主要特性,电路图,材料清单和变压电路图。
ICL8001G 产品亮点:
• Quasi-Resonant Control For Highly Efficient LED Driving Solutions
• Primary Side Flyback Control With Integrated PFC And Phase-Cut Dimming
• Integrated HV Startup Cell For Short Time To Light
• Best In Class System BOM For Dimmable LED Bulb
ICL8001G主要特性:
• High, stable efficiency over wide operating range
• Optimized for trailing- and leading-edge dimmer
• Precise PWM for primary PFC and dimming control
• Power cell for Vcc pre-charging with constant current
• Built-in digital soft-start
• Foldback correction and cycle-by-cycle peak current limitation
• VCC over/ under-voltage lockout
• Auto restart mode for short circuit protection
• Adjustable latch-off mode for output overvoltage protection
图1。ICL8001G方框图
图2。ICL8001G初级控制应用电路图
EVAL-LED-ICL8001G-Bulb02 Quasi-Resonant Flyback Converter for Phase Cut Dimming with High Power Factor
The EVAL-LED-ICL8001G-Bulb02 demonstrates the single-stage flyback and PFC controller ICL8001G in an LED Bulb application. Its quasiresonant operation mode, primary side control, integrated PFC and phase-cut dimming control makes it the best in class system solution for dimmable LED bulbs.
EVAL-LED-ICL8001G-Bulb02演示板主要特性:
•High, stable efficiency over wide operating range through quasiresonant operation mode
•Primary side side flyback control with integrated PFC and phase-cut dimming
•Energy efficient phase cut dimming
•Power cell for VCC pre-charging with constant current
•Built-in digital soft-start
•Foldback correction and cycle-by-cycle peak current limitation
•VCC over- and under-voltage lockout
•Auto restart mode for short circuit protection
•Adjustable latch-off mode for output overvoltage protection
•Best in class system BOM for dimmable bulbs
图3。EVAL-LED-ICL8001G-Bulb02演示板外形图
图4。EVAL-LED-ICL8001G-Bulb02演示板电路
EVAL-LED-ICL8001G-Bulb02演示板材料清单(BOM):
图5。EVAL-LED-ICL8001G-Bulb02演示板变压器电路图
