收音机模块TEA5767的C51控制程序
编程实验
72人已加入
  TEA5767采用I2C或者三线接口控制,我是用的I2C,单片机用STC89C52,带1K EEPROM,可以掉电存台,1602LCD显示.
  TEA5767读写数据都是5个字节,其中PLL参数14位,具体数据格式请看datasheet.以下程序中的函数可以直接在主程序中调用.
  #include "iic.c"
  #define max_freq 108000
  #define min_freq 87500
  unsigned char radio_write_data[5]={0x29,0xc2,0x20,0x11,0x00}; //要写入TEA5767的数据
  unsigned char radio_read_data[5]; //TEA5767读出的状态
  unsigned int default_pll=0x29c2;//0x29f9; //默认存台的pll,87.8MHz
  //unsigned int max_pll=0x339b; //108MHz时的pll,
  //unsigned int min_pll=9000; //70MHz时的pll
  void radio_write(void)
  unsigned char i;
  iic_start();
  iic_write8bit(0xc0); //TEA5767写地址
  if(!iic_testack())
  for(i=0;i<5;i++)
  iic_write8bit(radio_write_data[i]);
  iic_ack();
  iic_stop();
  //读TEA5767状态,并转换成频率
  void radio_read(void)
  unsigned char i;
  unsigned char temp_l,temp_h;
  pll=0;
  iic_start();
  iic_write8bit(0xc1); //TEA5767读地址
  if(!iic_testack())
  for(i=0;i<5;i++)
  radio_read_data[i]=iic_read8bit();
  iic_ack();
  iic_stop();
  temp_l=radio_read_data[1];
  temp_h=radio_read_data[0];
  temp_h&=0x3f;
  pll=temp_h*256+temp_l;
  get_frequency();
  //由频率计算PLL
  void get_pll(void)
  unsigned char hlsi;
  unsigned int twpll=0;
  hlsi=radio_write_data[2]&0x10;
  if (hlsi)
  pll=(unsigned int)((float)((frequency+225)*4)/(float)32.768); //频率单位:k
  else
  pll=(unsigned int)((float)((frequency-225)*4)/(float)32.768); //频率单位:k
  //由PLL计算频率
  void get_frequency(void)
  unsigned char hlsi;
  unsigned int npll=0;
  npll=pll;
  if (hlsi)
  frequency=(unsigned long)((float)(npll)*(float)8.192-225); //频率单位:KHz
  else
  frequency=(unsigned long)((float)(npll)*(float)8.192+225); //频率单位:KHz
  //手动设置频率,mode=1,+0.1MHz; mode=0:-0.1MHz ,不用考虑TEA5767用于搜台的相关位:SM,SUD
  void search(bit mode)
  radio_read();
  if(mode)
  frequency+=100;
  if(frequency>max_freq)
  frequency=min_freq;
  else
  frequency-=100;
  if(frequency
  frequency=max_freq;
  get_pll();
  radio_write_data[0]=pll/256;
  radio_write_data[1]=pll%256;
  radio_write_data[2]=0x20;
  radio_write_data[3]=0x11;
  radio_write_data[4]=0x00;
  radio_write();
  //自动搜台,mode=1,频率增加搜台; mode=0:频率减小搜台,不过这个好像不能循环搜台
  void auto_search(bit mode)
  radio_read();
  get_pll();
  if(mode)
  radio_write_data[2]=0xa0;
  else
  radio_write_data[0]=pll/256+0x40;
  radio_write();
  radio_read();
  while(!(radio_read_data[0]&0x80)) //搜台成功标志
  radio_read();
  disp_freq(9,1);
  • 相关推荐
  • 热点推荐
  • TEA5767
