MAX34441 PMBus的5通道电源管理器和智能风扇控制
新品快讯
30人已加入
MAX34441 PMBus 5-Channel Power-Supply Manager and Intelligent Fan Controller
概述
The MAX34441 is a complex system monitor that can manage up to five power supplies and a fan. The power-supply manager monitors the power-supply output voltage and constantly checks for user-programmable overvoltage and undervoltage thresholds. It can also margin the power-supply output voltage up or down to a user-programmable level. The margining is performed in a closed-loop arrangement whereby the device automatically adjusts a pulse-width-modulated (PWM) output and then measures the resultant output voltage. The power-supply manager can also sequence the supplies in any order at both power-up and power-down. With the addition of an external current-sense amplifier, the device can also monitor currents.
The device also contains closed-loop fan-speed control. Based on user-programmable settings for fan-control PWM duty cycles or RPM speeds at particular temperature breakpoints, the device automatically adjusts the fan speed in a manner to reduce audible noise and power consumption.
关键特性
  • 5 Channels of Power-Supply Management
    • Voltage Measurement/Monitoring
      • Differential 12-Bit 1% Accurate ADC
      • Min/Max Threshold Excursion Detection
    • Supports Current Monitoring with External Current-Sense Amplifier
    • Automatic Closed-Loop Margining
    • Programmable Up and Down Sequencing
    • Power-Good Output
  • 1 Channel of Fan Control
    • Supports 3-Wire and 4-Wire Fans
    • Automatic Closed-Loop Fan-Speed Control
    • Support for Dual Tachometer Fans
    • Fan-Fault Detection
  • Supports Up to Six Temperature Sensors
    • External Thermal Diode Interface with Automatic Series Resistance Cancellation
    • One Internal Temperature Sensor
    • Support for Up to Four Additional I²C Digital Temp Sensor ICs
    • Fault Detection on All Temp Sensors
  • PMBus™-Compliant Command Interface
  • I²C/SMBus™-Compatible Serial Bus with Bus Timeout Function
  • On-Board Nonvolatile Fault Logging and Default Configuration Setting
  • No External Clocking Required
  • +3.3V Supply Voltage
    应用/使用
    基站
    工业控制
    网络交换机/路由器
    服务器
    智能卡网络系统
    PM
    Typical Operating Circuit
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • PM
