IC应用电路图
RT8482应用电路(高电压高电流LED驱动器控制器)
The RT8482 is a current mode PWM controller designed to drive an external MOSFET for high current LED applications. With a current sense amplifier threshold of 190mV, the LED current is programmable with one external current sense resistor. With a maximum operating input voltage of 36V and output voltage up to 48V, the RT8482 is ideal for buck, boost or buck-boost operation. |
| Ordering Info |
Note : |
| Features |
• High Voltage Capability : VIN Up to 36V, VOUT Up to 48V • Buck, Boost or Buck Boost Operation • Current Mode PWM with 350kHz Switching Frequency • Easy Dimming : Analog, PWM Digital or PWM Converting to Analog with One External Capacitor • Programmable Soft Start to Avoid Inrush Current • Programmable Over Voltage Protection • VIN Under Voltage Lockout and Thermal Shutdown • 16-Lead WQFN and SOP Packages • RoHS Compliant and Halogen Free |
| Application |
• General Industrial High Power LED Lighting
• Desk Lights and Room Lighting • Building and Street Lighting • Industrial Display Backlight |
| Pin Configurations |
( VIEW) SOP-16 WQFN-16L 3x3 |
| Typical Applications Circuit |
Figure 1. Analog Dimming in Boost Configuration Figure 2. PWM to Analog Dimming in Boost Configuration Figure 3. Analog Dimming in Buck-Boost Configuration Figure 4. Analog Dimming in Buck Configuration |
