IC应用电路图
RT8470应用电路 (1.2A/1A,迟滞,高亮度LED驱动器) The RT8470 is a high efficiency, continuous mode inductive step-down converter, designed for driving single or multiple series connected LEDs from a voltage source higher than the LED voltage. It operates from an input voltage of 7V to 30V and employs hysteretic control with a high side current sense resistor to set the constant output current. |
更详细介绍:http://www.elecfans.com/soft/39/2010/2010093090873.html |
Ordering Info |
Note : |
| Features |
• 7V to 30V Input Voltage Range • Hysteretic Control with High Side Current Sensing • Internal N-MOSFETs with 350mW Low RDS(ON) • 1A Output Current (For TSOT-23-5 Only) • 1.2A Output Current (For SOP-8 (Exposed Pad) Only) • Up to 95% Efficiency • Typical ±3% LED Current Accuracy • Analog or PWM Control Signal for LED Dimming • 300Hz On-Board Ramp Generator • Input Under Voltage Lockout • Thermal Shutdown Protection • RoHS Compliant and Halogen Free |
| Application |
• Automotive LED Lighting • High Power LED Lighting • Indicator and Emergency Lighting • Architectural Lighting • Low Voltage Industrial Lighting • Signage and Decorative LED Lighting |
| Pin Configurations |
( VIEW) TSOT-23-5 SOP-8 (Exposed Pad) |
| Typical Applications Circuit |
