IC应用电路图
RT8453/RT8453B应用电路(40V的高电压降压型LED驱动器)
The RT8453B is a buck current mode PWM regulator for LED driving applications. It provides an integrated 1.5A switch and can be operated with a wide input voltage range from 4.5V to 40V. With a 500kHz operating frequency, the RT8453B allows all external inductor and input/output capacitors to be small. High efficiency is achieved with its 190mV current sensing capability. Dimming can be either analog or PWM digital signal driven. The RT8453B is available in a small SOP-8 (Exposed pad) package. 更多详细介绍:http://www.elecfans.com/soft/39/2010/2010093090875.html |
| Ordering Info |
Note : |
| Features |
• Input Operating Range 4.5 to 40V • 1.5A Switching Current Limitation • 10% Constant Current Output Accuracy • Current Mode PWM with 500kHz Switching Frequency • Analog or PWM Control Signal for LED Dimming • Programmable Soft Start • Input Under Voltage Lockout • Over Temperature Protection • RoHS Compliant and Halogen Free |
| Application |
• General Illumination • Desk Lights and Room Lighting • Industrial Backlight/Lighting • Constant Current Source |
| Pin Configurations |
( VIEW)
| Typical Applications Circuit |
