新品快讯
MAX9530 四通道NTSC/PAL解码器和四通道音频编码器
以最低的系统成本连接4路模拟视频、音频输入与Maxim的MG3500
概述
The MAX9530 is a quad-channel video decoder and audio codec for security applications. The part is specially designed to serve as the analog video front-end in multichannel DVRs (digital video recorders) and multicamera systems. The architecture supports byte- or frame-interleaved digital video output for direct connection to Maxim’s own H.264 codec family (i.e., MG3500 and later generations). The on-chip DDR2 memory controller enables output of frame-synchronized digital video from up to four asynchronous analog video inputs. The use of external memory is optional. Without any external memory, bypass mode provides for output of up to four separate channels of asynchronous video data in BT.656 digital component format. Excellent video quality and noise immunity are achieved with the use of differential input mode, integrated automatic video EQ, and the industry's best specifications for interchannel crosstalk.
更多视频编码器请查看:http://www.elecfans.com/soft/special/encoders/
关键特性
4-Channel Analog Video Decoder—NTSC or PAL (All Variations)
4-Channel Frame-Interleaved Output Synchronizer with the Use of Optional External DDR2 Memory
With DDR2—Pixel or Frame Interleaved
Without DDR2—BT.656 Pixel (Byte) Multiplex
Programmable 2D Video Scalers
Independent Auto Cable EQ per Video Channel
Instant Lock System for Video Capture
Multiline Adaptive Comb Filters
4x Oversampled 54MHz/10-Bit Video ADC
4-Channel Analog Audio Input (Mono)
48kHz/16-Bit Audio ADC
2-Channel Analog Audio Output
Differential or Single-Ended Analog Inputs
I²C Interface
4-Channel of 8/16-Bit Audio
1.8V Analog Supply Voltage
1.8V Digital Core Supply Voltage
1.8V to 3.3V Digital I/O Voltage
应用/使用
数字视频IP编码器
数字视频监测器
数字录像机(DVR)
多摄像机监控系统
多通道音频/视频采集
