MAX9613, MAX9615应用电路
IC应用电路图
512人已加入
The MAX9613/MAX9615 are low-power precision op amps with rail-to-rail inputs and rail-to-rail outputs. They feature precision MOS inputs powered from an internal charge pump to eliminate crossover distortion that is common to complementary input-pair type amplifier architectures.
These devices are ideal for a large number of signal processing applications such as photodiode transimpedance amplifiers and filtering/amplification of a wide variety of signals in industrial equipment. The devices also feature excellent RF immunity, making them ideal for portable applications.
The MAX9613/MAX9615 feature a self-calibration system (on power-up), eliminating the effects of temperature and power-supply variations.
The MAX9613/MAX9615 are capable of operating from a 1.7V to 5.5V supply voltage over the 0°C to +70°C temperature range, and from 1.8V to 5.5V over the -40°C to +125°C automotive temperature range.
Both singles and duals are available in tiny SC70 packages. The MAX9613 features a high-impedance output while in shutdown.
典型应用电路
MAX9613, MAX9615,pdf datasheet请查看: http://www.elecfans.com/soft/39/2010/2010100791524.html
  • 相关推荐
  • 热点推荐
  • MAX9613
