THS7364设计的六路低功耗HD(SD)视频技术
稳压电源
160人已加入
本文介绍了THS7364功能方框图,多种应用电路图以及THS7364EVM评估板主要特性,电路图,材料清单和PCB布局图.
THS7364是TI 公司的采用SiGe BiCom3X工艺的六路低功耗HD(SD)视频缓冲器,集成了三个SDTV滤波器(9.5-MHz)和三个全HD的HDTV滤波器(72-MHz),所有滤波器具有可旁通的6阶Butterworth特性, 内置增益6-dB (2 V/V) ,单电源+2.7V 到+5V工作,主要用在STB,PVR/DVDR和BluRay输出视频缓冲器.
THS7364应用:
Set Top Box Output Video Buffering
PVR/DVDR Output Buffering
BluRay™ Output Video Buffer
THS7364
图1.THS7364功能方框图
THS7364
图2.THS7364单电源DC输入/DC输出耦合视频线路驱动器
THS7364
图3.THS7364典型的6路系统:DC耦合编码器/DAC输入/,DC耦合线路驱动
THS7364
图4.THS7364典型的6路系统:DC耦合线路驱动,每路两个输出
THS7364
图5.THS7364典型AC输入系统驱动AC耦合视频线路
THS7364EVM评估板
The THS7364EVM is an evaluation module for the THS7364 in the PW (20-lead TSSOP) package. The THS7364EVM is designed to quickly and easily demonstrate the functionality and versatility of the device. The EVM is ready for power, signal source, and test instruments. The EVM is configured with a 75 ohm input and output termination. The THS7364 evaluation module (EVM) User’s Guide is included within the Product Datasheet.
THS7364EVM评估板主要特性:
Configured with 75 ohms input/output impedance
Single Supply: 2.7V to 5V Decoupling capacitors
Connectors: Vs+, GND, INPUT, OUTPUT and test points
Input and output connectors support both BNC and RCA/S-video connections
Four Jumpers allow device configuration for SD-disable, FHD-Disable, SD-bypass, FHD-bypass
THS7364
图6.THS7364EVM评估板电路图
THS7364EVM评估板材料清单(BOM):
THS7364
图7.THS7364EVM PCB顶层布局图
