led调光驱动电路
LED电路
115人已加入
SSL2101/SSL2102 12W调光LED驱动器
The SSL2101/2102 12 W LED driver is a solution for a professional application with multiple high power LEDs that requires galvanic isolation and a safe output voltage. It is mains dimmable for both forward phase (TRIAC) dimmers, and reverse phase (Transistor)dimmers. It can generate up to 16 W output power, which is equal to a 100 W incandescent lamp (at 63 Lumen/W). Examples are shelf lighting, down lighting, LED lighting for bathrooms etc.The design gives an example of how to make a drive that is suitable for small form factor applications like retrofit lamps.
The board needs to be connected to mains voltage. Touching the reference board during operation must be avoided at all times. An isolated housing is obligatory when used in uncontrolled, non laboratory environments. Even though the secondary circuit with LED connection has a galvanic isolation, this isolation is not according to any regulated norm. Galvanic isolation of the mains phase using a variable transformer is always recommended.
The board can be optimized for a 230 V (AC) (50 Hz) or for a 120 V (AC) (60 Hz) mains source. Besides the mains voltage optimization, the board is designed to work with multiple high power LEDs with a total working voltage of between 9 V and 23 V.
The output current can be limited using trimmer R20. On request, a dedicated LED load can be delivered that is to be connected to K3. Connector K2 can be used to attach other LED loads. The output voltage is limited to 25 V. When attaching a LED load to an operational board (hot plugging) an inrush peak current will occur due to discharge of capacitor C6.After frequent discharges, the LEDs may deteriorate or become damaged.
图4.12W调光LED驱动器外形图
LED电路
图5.12W调光LED驱动器电路图
材料清单(BOM)(230VAC):
LED电路
LED电路
材料清单(BOM)(120VAC):
LED电路
SSL2101开关电源集成电路可调光LED照明:http://www.elecfans.com/soft/70/2009/2009103151737.html
评论(0)
发评论
baikeqqa 2021-03-19
0 回复 举报
元件清单都给出来了,学习下 收起回复
老坑菜鸟 2019-02-09
0 回复 举报
高级资料啊,全英文,但就是好 收起回复
全部评论
