使用AT指令进行Hi3861 WiFi操作
摘要
 本文简单介绍Hi3861WiFi操作,怎么连接到热点,查看IP,ping服务器等。
适合群体
 适用于润和Hi3861开发板的开发。
1、AT指令操作WiFi
 我们可以使用AT指令进行Hi3861 WiFi操作,连接热点、ping服务器等。
Hi3861
但是很多时候,我们需要实现开机后自动连接到某个热点,光靠AT指令不行。
Hi3861 为我们提供了WiFi操作的相关API,方便我们编写代码,实现热点连接。
2、代码实现
 先直接上代码和操作演示,跟我们最早的hello world代码一样,在app下新增业务demo_wifi_sta,其中demo_wifi_sta.c为业务代码,BUILD.gn为编译脚本,具体规划目录结构如下:
Hi3861
其中BUILD.gn文件内容如下:
static_library("demo_wifi_sta") {    sources = [        "demo_wifi_sta.c"    ]
    include_dirs = [        "//utils/native/lite/include",        "//kernel/liteos_m/components/cmsis/2.0",        "//base/iot_hardware/peripheral/interfaces/kits",        "//device/soc/hisilicon/hi3861v100/hi3861_adapter/hals/communication/wifi_lite/wifiservice",        "//device/soc/hisilicon/hi3861v100/hi3861_adapter/kal",        "//device/soc/hisilicon/hi3861v100/sdk_liteos/third_party/lwip_sack/include",    ]}
向右滑动查看完整代码
hi_wifi_start_sta函数:设置WiFi参数、扫描热点
int hi_wifi_start_sta(void){    int ret;    char ifname[WIFI_IFNAME_MAX_SIZE + 1] = {0};    int len = sizeof(ifname);    const unsigned char wifi_vap_res_num = APP_INIT_VAP_NUM;    const unsigned char wifi_user_res_num = APP_INIT_USR_NUM;    unsigned int  num = WIFI_SCAN_AP_LIMIT;
    //这里不需要重复进行WiFi init,因为系统启动后就自己会做WiFi init#if 0    printf("_______>>>>>>>>>> %s %d
", __FILE__, __LINE__);    ret = hi_wifi_init(wifi_vap_res_num, wifi_user_res_num);    if (ret != HISI_OK) {        return -1;    }#endif    ret = hi_wifi_sta_start(ifname, &len);    if (ret != HISI_OK) {        return -1;    }
    /* register call back function to receive wifi event, etc scan results event,     * connected event, disconnected event.     */    ret = hi_wifi_register_event_callback(wifi_wpa_event_cb);    if (ret != HISI_OK) {        printf("register wifi event callback failed
    /* acquire netif for IP operation */    g_lwip_netif = netifapi_netif_find(ifname);    if (g_lwip_netif == NULL) {        printf("%s: get netif failed
", __FUNCTION__);        return -1;    }
    /* 开始扫描附件的WiFi热点 */    ret = hi_wifi_sta_scan();    if (ret != HISI_OK) {        return -1;    }
    sleep(5);   /* sleep 5s, waiting for scan result. */
    hi_wifi_ap_info *pst_results = malloc(sizeof(hi_wifi_ap_info) * WIFI_SCAN_AP_LIMIT);    if (pst_results == NULL) {        return -1;    }
    //把扫描到的热点结果存储起来    ret = hi_wifi_sta_scan_results(pst_results, &num);    if (ret != HISI_OK) {        free(pst_results);        return -1;    }
    //打印扫描到的所有热点    for (unsigned int loop = 0; (loop < num) && (loop < WIFI_SCAN_AP_LIMIT); loop++) {        printf("SSID: %s
", pst_results[loop].ssid);    }    free(pst_results);
    /* 开始接入热点 */    ret = hi_wifi_start_connect();    if (ret != 0) {        return -1;    }    return 0;}
向右滑动查看完整代码
连接热点:
int hi_wifi_start_connect(void){    int ret;    errno_t rc;    hi_wifi_assoc_request assoc_req = {0};
    /* copy SSID to assoc_req */    rc = memcpy_s(assoc_req.ssid, HI_WIFI_MAX_SSID_LEN + 1, "RedmiK40", 8); /* 9:ssid length */    if (rc != EOK) {        return -1;    }
    //热点加密方式    assoc_req.auth = HI_WIFI_SECURITY_WPA2PSK;
    /* 热点密码 */    memcpy(assoc_req.key, "07686582488", 11);
    ret = hi_wifi_sta_connect(&assoc_req);    if (ret != HISI_OK) {        return -1;    }
    return 0;}
向右滑动查看完整代码
热点连接结果回调函数
void wifi_wpa_event_cb(const hi_wifi_event *hisi_event){    if (hisi_event == NULL)        return;
    switch (hisi_event->event) {        case HI_WIFI_EVT_SCAN_DONE:            printf("WiFi: Scan results available
");            break;        case HI_WIFI_EVT_CONNECTED:            printf("WiFi: Connected
");            netifapi_dhcp_start(g_lwip_netif);            break;        case HI_WIFI_EVT_DISCONNECTED:            printf("WiFi: Disconnected
");            netifapi_dhcp_stop(g_lwip_netif);            hi_sta_reset_addr(g_lwip_netif);            break;        case HI_WIFI_EVT_WPS_TIMEOUT:            printf("WiFi: wps is timeout
");            break;        default:            break;    }}
向右滑动查看完整代码
hi_sta_reset_addr:重新复位sta的地址、网关等参数。
/* clear netif's ip, gateway and netmask */void hi_sta_reset_addr(struct netif *pst_lwip_netif){    ip4_addr_t st_gw;    ip4_addr_t st_ipaddr;    ip4_addr_t st_netmask;
    if (pst_lwip_netif == NULL) {        printf("hisi_reset_addr::Null param of netdev
");        return;    }
    IP4_ADDR(&st_gw, 0, 0, 0, 0);    IP4_ADDR(&st_ipaddr, 0, 0, 0, 0);    IP4_ADDR(&st_netmask, 0, 0, 0, 0);
    netifapi_netif_set_addr(pst_lwip_netif, &st_ipaddr, &st_netmask, &st_gw);}
向右滑动查看完整代码
3、WiFi相关API
 Hi3861 提供了非常多的wifi相关API,主要文件是 hi_wifi_api.h,我们这里只列举最重要的几个API
(1)开启STA
int hi_wifi_sta_start(char *ifname, int *len);
向右滑动查看完整代码
(2)停止STA
int hi_wifi_sta_stop(void);
向右滑动查看完整代码
(3)扫描附件的热点
int hi_wifi_sta_scan(void);
向右滑动查看完整代码
(4)连接热点
int hi_wifi_sta_connect(hi_wifi_assoc_request *req);
向右滑动查看完整代码
其中hi_wifi_assoc_request *req 结构的定义如下:
typedef struct {    char ssid[HI_WIFI_MAX_SSID_LEN + 1];    /**< SSID. CNcomment: SSID 只支持ASCII字符.CNend */    hi_wifi_auth_mode auth;                 /**< Authentication mode. CNcomment: 认证类型.CNend */    char key[HI_WIFI_MAX_KEY_LEN + 1];      /**< Secret key. CNcomment: 秘钥.CNend */    unsigned char bssid[HI_WIFI_MAC_LEN];   /**< BSSID. CNcomment: BSSID.CNend */    hi_wifi_pairwise pairwise;              /**< Encryption type. CNcomment: 加密方式,不需指定时置0.CNend */} hi_wifi_assoc_request;
向右滑动查看完整代码
这里需要注意的是,通常加密方式是:HI_WIFI_SECURITY_WPA2PSK
例如我家的热点的连接方式的代码实现如下:
    return 0;}
向右滑动查看完整代码
本小节文章就到这里了,后续文章会持续更新,欢迎大家持续关注哦~
原文标题:OpenHarmony轻量系统开发【9】WiFi之STA模式连接热点
 文章出处:【微信公众号:HarmonyOS官方合作社区】欢迎添加关注!文章转载请注明出处。
 审核编辑:汤梓红
