粘贴版是一个常用的功能,用户通过系统剪贴板服务,可实现应用之间的简单数据传递。例如:在应用A中复制的数据,可以在应用B中粘贴,反之亦可。
效果如图:
关键代码如下:
public class PasteboardUtils {
private static final HiLogLabel TAG = new HiLogLabel(HiLog.LOG_APP,0x0,"蛟龙腾飞--粘贴版");
private SystemPasteboard pasteboard;
public PasteboardUtils(Context context) {
initPasteboard(context);
// 复制到粘贴板
public void copyText(String text) {
pasteboard.setPasteData(PasteData.creatPlainTextData(text));
// 粘贴
public String pasteText() {
String result = "";
PasteData pasteData = pasteboard.getPasteData();
if (pasteData == null) {
return result;
PasteData.DataProperty dataProperty = pasteData.getProperty();
boolean hasHtml = dataProperty.hasMimeType(PasteData.MIMETYPE_TEXT_HTML);
boolean hasText = dataProperty.hasMimeType(PasteData.MIMETYPE_TEXT_PLAIN);
if (hasHtml || hasText) {
for (int i = 0; i < pasteData.getRecordCount(); i++) {
PasteData.Record record = pasteData.getRecordAt(i);
String mimeType = record.getMimeType();
if (mimeType.equals(PasteData.MIMETYPE_TEXT_HTML)) {
result = record.getHtmlText();
} else if (mimeType.equals(PasteData.MIMETYPE_TEXT_PLAIN)) {
result = record.getPlainText().toString();
} else {
HiLog.info(TAG, "%{public}s", "getPasteData mimeType :" + mimeType);
return result;
// 监听粘贴版内容
private final IPasteDataChangedListener listener = new IPasteDataChangedListener() {
@Override
public void onChanged() {
if (pasteData != null) {
HiLog.info(TAG,"粘贴版内容改变:"+pasteData);
// 清空粘贴板
public void clearPasteboard(Component component) {
if (pasteboard != null) {
pasteboard.clear();
//初始化
private void initPasteboard(Context context) {
pasteboard = SystemPasteboard.getSystemPasteboard(context);
pasteboard.addPasteDataChangedListener(listener);
