MAX9632应用电路
IC应用电路图
512人已加入
MAX9632
MAX9632应用电路
MAX9632 pdf datasheet:http://www.elecfans.com/soft/39/2010/2010110894310.html
The MAX9632 is a low-noise, precision, wide-band operational amplifier that can operate in a very wide +4.5V to +36V supply voltage range. The IC operates in dual (±18V) or single-supply mode (36V).
The exceptionally fast settling time and low distortion make the IC an excellent solution for precision acquisition systems. The rail-to-rail output swing maximizes the dynamic range when driving high-resolution 24-bit ΣΔ ADCs even with low supply voltages.
The IC achieves 55MHz of gain-bandwidth product and ultra-low 0.94nV/ input voltage noise with only 3.9mA of quiescent current.
The IC is offered in 8-pin SO and TDFN packages and is rated for operation over the -40°C to +125°C temperature range.
  • 相关推荐
  • 热点推荐
  • MAX9632
