XADC内嵌在PS端的使用
Zynq
  XADC内嵌在PS端,允许CPU或其他主机连接XADC,而不用使用PL端。XADC最大采样率为1MSPS,精度为12bits,内置电压和温度传感器,可监测芯片的电压及温度信息。如图所示电压传感器可监测芯片的VCCINT,VCCAUX,VCCBRAM等,VP_0和VN_0为一对专用的ADC模拟输入口。VAUXP[*]和VAUXN[*]也是ADC输入口,但是不用作ADC输入口时,可用作普通IO使用。
Zynq
int XAdcPolledPrintfExample(u16 XAdcDeviceId)
    int Status;
    XAdcPs_Config *ConfigPtr;
    u32 TempRawData;
    u32 VccPintRawData;
    u32 VccPauxRawData;
    u32 VccPdroRawData;
    float TempData;
    float VccPintData;
    float VccPauxData;
    float MaxData;
    float MinData;
    XAdcPs *XAdcInstPtr = &XAdcInst;
    printf(" Entering the XAdc PolledExample. ");
     * Initialize the XAdc driver.
    ConfigPtr= XAdcPs_LookupConfig(XAdcDeviceId);
    if (ConfigPtr == NULL) {
        return XST_FAILURE;
    XAdcPs_CfgInitialize(XAdcInstPtr,ConfigPtr,
                ConfigPtr->BaseAddress);
     * Self Test the XADC/ADC device
    Status= XAdcPs_SelfTest(XAdcInstPtr);
    if (Status != XST_SUCCESS) {
        return XST_FAILURE;
     * Disable the Channel Sequencer beforeconfiguring the Sequence
     * registers.
    XAdcPs_SetSequencerMode(XAdcInstPtr,XADCPS_SEQ_MODE_SAFE);
     * Read the on-chip Temperature Data(Current/Maximum/Minimum)
     * from the ADC data registers.
    TempRawData= XAdcPs_GetAdcData(XAdcInstPtr, XADCPS_CH_TEMP);
    TempData= XAdcPs_RawToTemperature(TempRawData);
    printf(" The Current Temperature is%0d.%03d Centigrades. ",
                (int)(TempData), XAdcFractionToInt(TempData));
    TempRawData= XAdcPs_GetMinMaxMeasurement(XAdcInstPtr, XADCPS_MAX_TEMP);
    MaxData= XAdcPs_RawToTemperature(TempRawData);
    printf("The Maximum Temperature is%0d.%03d Centigrades. ",
                (int)(MaxData), XAdcFractionToInt(MaxData));
    TempRawData= XAdcPs_GetMinMaxMeasurement(XAdcInstPtr, XADCPS_MIN_TEMP);
    MinData= XAdcPs_RawToTemperature(TempRawData & 0xFFF0);
    printf("The Minimum Temperature is%0d.%03d Centigrades. ",
                (int)(MinData), XAdcFractionToInt(MinData));
     * Read the VccPint Votage Data(Current/Maximum/Minimum) from the
     * ADC data registers.
    VccPintRawData= XAdcPs_GetAdcData(XAdcInstPtr, XADCPS_CH_VCCPINT);
    VccPintData= XAdcPs_RawToVoltage(VccPintRawData);
    printf(" The Current VCCPINT is%0d.%03d Volts. ",
            (int)(VccPintData),XAdcFractionToInt(VccPintData));
    VccPintRawData= XAdcPs_GetMinMaxMeasurement(XAdcInstPtr,
                            XADCPS_MAX_VCCPINT);
    MaxData= XAdcPs_RawToVoltage(VccPintRawData);
    printf("The Maximum VCCPINT is %0d.%03dVolts. ",
                            XADCPS_MIN_VCCPINT);
    MinData= XAdcPs_RawToVoltage(VccPintRawData);
    printf("The Minimum VCCPINT is %0d.%03dVolts. ",
     * Read the VccPaux Votage Data(Current/Maximum/Minimum) from the
    VccPauxRawData= XAdcPs_GetAdcData(XAdcInstPtr, XADCPS_CH_VCCPAUX);
    VccPauxData= XAdcPs_RawToVoltage(VccPauxRawData);
    printf(" The Current VCCPAUX is%0d.%03d Volts. ",
            (int)(VccPauxData),XAdcFractionToInt(VccPauxData));
    VccPauxRawData= XAdcPs_GetMinMaxMeasurement(XAdcInstPtr,
                                XADCPS_MAX_VCCPAUX);
    MaxData= XAdcPs_RawToVoltage(VccPauxRawData);
    printf("The Maximum VCCPAUX is %0d.%03dVolts. ",
                                XADCPS_MIN_VCCPAUX);
    MinData= XAdcPs_RawToVoltage(VccPauxRawData);
    printf("The Minimum VCCPAUX is %0d.%03dVolts. ",
     * Read the VccPdro Votage Data(Current/Maximum/Minimum) from the
    VccPdroRawData= XAdcPs_GetAdcData(XAdcInstPtr, XADCPS_CH_VCCPDRO);
    VccPintData= XAdcPs_RawToVoltage(VccPdroRawData);
    printf(" The Current VCCPDDRO is%0d.%03d Volts. ",
            (int)(VccPintData), XAdcFractionToInt(VccPintData));
    VccPdroRawData= XAdcPs_GetMinMaxMeasurement(XAdcInstPtr,
                            XADCPS_MAX_VCCPDRO);
    MaxData= XAdcPs_RawToVoltage(VccPdroRawData);
    printf("The Maximum VCCPDDRO is %0d.%03dVolts. ",
                            XADCPS_MIN_VCCPDRO);
    MinData= XAdcPs_RawToVoltage(VccPdroRawData);
    printf("The Minimum VCCPDDRO is %0d.%03dVolts. ",
    printf("Exiting the XAdc Polled Example. ");
    return XST_SUCCESS;
* This function converts the fractionpart of the given floating point number
* (after the decimal point)to aninteger.
* @param    FloatNum is the floating point number.
* @return   Integer number to a precision of 3 digits.
* @note
* This function is used in the printingof floating point data to a STDIO device
* using the xil_printf function. Thexil_printf is a very small foot-print
* printf function and does notsupport the printing of floating point numbers.
int XAdcFractionToInt(float FloatNum)
    float Temp;
    Temp= FloatNum;
    if (FloatNum < 0) {
        Temp= -(FloatNum);
    return( ((int)((Temp -(float)((int)Temp)) * (1000.0f))));
Zynq
原文标题:Zynq中PS端XADC
文章出处:【微信公众号:FPGA之家】欢迎添加关注!文章转载请注明出处。
审核编辑:汤梓红
