LTC1540-Nanopower Comparator w
IC应用电路图
512人已加入
LTC1540描述
The LTC®1540 is an ultralow power, single comparator with built-in reference. The comparator’s features include less than 0.6µA supply current over the commercial temperature range, a 1.182V ±2% reference, programmable hysteresis and TTL/CMOS outputs that sink and source current. The reference output can drive a bypass capacitor of up to 0.01µF without oscillation.
The comparator operates from a single 2V to 11V supply or a dual ±1V to ±5.5V supply. Comparator hysteresis is easily programmed by using two resistors and the HYST pin. Each comparator’s input operates from the negative supply to within 1.3V of the positive supply. The comparator output stage can continuously source up to 40mA. By eliminating the cross-conducting current that normally occur when the comparator changes logic states, power supply glitches are eliminated.
The LTC1540 is available in the 8-pin MSOP and SO packages. For space limited applications, the LTC1540 is available in a 3mm x 3mm low profile (0.8mm) dual finepitch leadless package (DFN).
LTC1540特点
Ultralow Quiescent Current: 0.3µA Typ
Reference Output Drives 0.01µF Capacitor
Adjustable Hysteresis
Available in 3mm x 3mm x 0.8mm DFN Package
Wide Supply Range: 2V to 11V
Input Voltage Range Includes the Negative Supply
Reference Output Sources Up to 1mA
TTL/CMOS Compatible Outputs
60µs Propagation Delay with 10mV Overdrive
No Crowbar Current
40mA Continuous Source Current
Pin Compatible with LTC1440, MAX921, MAX931
Typical Application
LTC1540封装
MSOP-8, SO-8, DFN-8
LTC1540应用
Battery-Powered System Monitoring
Threshold Detectors
Window Comparators
Oscillator Circuits
