LTC1563-2-有源RC、4阶低通滤波器系列
IC应用电路图
512人已加入
LTC1563描述
The LTC®1563-2/LTC1563-3 are a family of extremely easy-to-use, active RC lowpass filters with rail-to-rail inputs and outputs and low DC offset suitable for systems with a resolution of up to 16 bits. The LTC1563-2, with a single resistor value, gives a unity-gain Butterworth response. The LTC1563-3, with a single resistor value, gives a unity-gain Bessel response. The proprietary architecture of these parts allows for a simple resistor calculation: R = 10k (256kHz/fC); fC = Cutoff Frequency where fC is the desired cutoff frequency. For many applications, this formula is all that is needed to design a filter. By simply utilizing different valued resistors, gain and other responses are achieved. The LTC1563-X features a low power mode, for the lower frequency applications, where the supply current is reduced by an order of magnitude and a near zero power shutdown mode. The LTC1563-Xs are available in the narrow SSOP-16 package (Same footprint as an SO-8 package).
LTC1563特点
Extremely Easy to Use—A Single Resistor Value Sets the Cutoff Frequency (256Hz < fC < 256kHz)
Extremely Flexible—Different Resistor Values Allow Arbitrary Transfer Functions with or without Gain (256Hz < fC<256kHz)
Supports Cutoff Frequencies Up to 360kHz Using FilterCAD™
LTC1563-2: Unity-Gain Butterworth Response Uses a Single Resistor Value, Different Resistor Values Allow Other Responses with or without Gain
LTC1563-3: Unity-Gain Bessel Response Uses a Single Resistor Value, Different Resistor Values Allow Other Responses with or without Gain
Rail-to-Rail Input and Output Voltages
Operates from a Single 3V (2.7V Min) to ±5V Supply
Low Noise: 36µVRMS for fC = 25.6kHz, 60µVRMS for fC = 256kHz
fC Accuracy < ±2% (Typ)
DC Offset < 1mV
Cascadable to Form 8th Order Lowpass Filters
Available in Narrow SSOP-16 Package
Typical Application
滤波器
LTC1563封装
SSOP-16
滤波器
LTC1563应用
Discrete RC Active Filters and Modules
Antialiasing Filters
Smoothing or Reconstruction Filters
Linear Phase Filtering for Data Communication
Phase Locked Loops
LTC1563仿真
FilterCAD 3.0 is a computer aided design program to help users without special expertise in filter design to create filters using Linear Technology's monolithic filter ICs. With FilterCAD, you can design filters with a variety of responses, including Butterworth, Bessel, Chebychev, elliptic, minimum Q elliptic, and custom responses.
