HarmonyOS应用开发—文件上传问题的解决方式
在之前的分享中,曾经提到一个文件上传的问题
/data/user/0/cn.jltf.neighbor/files/534.jpg: open failed: ENOENT (No such file)
该文件不存在。但实际上该文件存在并能显示出来。后来发现是鸿蒙系统的权限问题,只能访问私有目录下的文件。
解决方法:将文件复制到私有目录下,再进行访问。
代码如下:
 HiLog.info(label,"私有目录:"+this.getFilesDir());
        HiLog.info(label,"缓存目录:"+this.getCacheDir());
        HiLog.info(label,"数据目录:"+this.getDataDir());
        HiLog.info(label,"外部目录:"+this.getExternalCacheDir());
        HiLog.info(label,"引用目录:"+this.getPreferencesDir());
        HiLog.info(label,"同步目录:"+this.getDistributedDir());
        HiLog.info(label,"应用目录:"+this.getDir("", Context.MODE_PRIVATE));
        File[] dataChildFiles = this.getDataDir().listFiles();
        for (File dataChildFile : dataChildFiles) {
            HiLog.info(label,"数据子目录:"+dataChildFile);
        File[] externalFiles=this.getExternalMediaDirs();
        for (File externalFile : externalFiles) {
            HiLog.info(label,"外部Media目录:"+externalFile);
        try {
            //该目录和JSUI中的internal://cache/目录是一个目录
            File file=new File(this.getCacheDir()+"/111.jpg");
            HiLog.info(label,"文件路径:"+file);
            if(file.exists())
                HiLog.info(label,"文件已存在");
               return;
            HiLog.info(label,"文件不存在");
          InputStream inputStream = getContext().getResourceManager().getResource(ResourceTable.Media_icon);
            ImageSource.SourceOptions srcOpts = new ImageSource.SourceOptions();
            srcOpts.formatHint = "image/jpeg";
            ImageSource imageSource = ImageSource.create(inputStream, srcOpts);
            // 设置图片参数
            ImageSource.DecodingOptions decodingOptions = new ImageSource.DecodingOptions();
            decodingOptions.desiredSize=new Size(200,200);
            imageSource.createPixelmap(decodingOptions);
            //该种方式直接访问internal://app目录//            FileOutputStream fos=new FileOutputStream("/data/user/0/com.example.abilitytransfertest/files//111.jpg");
            FileOutputStream fos=new FileOutputStream(this.getCacheDir()+"/111.jpg");
            ImagePacker imagePacker = ImagePacker.create();
            ImagePacker.PackingOptions packingOptions = new ImagePacker.PackingOptions();
            packingOptions.format = "image/jpeg";
            packingOptions.quality = 90;
            boolean result = imagePacker.initializePacking(fos, packingOptions);
            if(result)
                result = imagePacker.addImage(imageSource.createPixelmap(decodingOptions));
                if (result) {
                    long dataSize = imagePacker.finalizePacking();
                    HiLog.info(label,"文件大小:"+dataSize);
            fos.flush();
            fos.close();
            if(file.exists())
                return;
        } catch (IOException | NotExistException e) {
            HiLog.info(label,"文件保存出错:"+e.getMessage());
            e.printStackTrace();
        File file=this.getCacheDir();
        File[] files = file.listFiles();
        for (File file1 : files) {
            HiLog.info(label,"File目录:"+file1);
审核编辑:符乾江
