LTC1967-精准扩展带宽、RMS至DC转换器
IC应用电路图
512人已加入
LTC1967描述
The LTC®1967 is a true RMS-to-DC converter that uses an innovative delta-sigma computational technique. The benefits of the LTC1967 proprietary architecture when compared to conventional log-antilog RMS-to-DC converters are higher linearity and accuracy, bandwidth independent of amplitude and improved temperature behavior.
The LTC1967 operates with single-ended or differential input signals (for EMI/RFI rejection) and supports crest factors up to 4. Common mode input range is rail-to-rail. Differential input range is 1VPEAK, and offers unprecedented linearity. The LTC1967 allows hassle-free system calibration at any input voltage.
The LTC1967 has a rail-to-rail output with a separate output reference pin providing flexible level shifting; it operates on a single power supply from 4.5V to 5.5V. A low power shutdown mode reduces supply current to 0.1µA.
The LTC1967 is packaged in the space-saving MSOP package, which is ideal for portable applications.
Protected under U.S. Patent Numbers 6,359,576, 6,362,677 and 6,516,291.
LTC1967特点
High Linearity:
0.02% Linearity Allows Simple System Calibration
Wide Input Bandwidth:
Bandwidth to 0.1% Additional Gain Error: 40kHz
Bandwidth Independent of Input Voltage Amplitude
No-Hassle Simplicity:
True RMS-DC Conversion with Only One External Capacitor
Delta Sigma Conversion Technology
Low Supply Current:
330µA Typ
Ultralow Shutdown Current:
0.1µA
Flexible Inputs:
Differential or Single Ended
Rail-to-Rail Common Mode Voltage Range
Up to 1VPEAK Differential Voltage
Flexible Output:
Rail-to-Rail Output
Separate Output Reference Pin Allows Level Shifting
Small Size:
Space Saving 8-Pin MSOP Package
Typical Application
RM
LTC1967封装
MSOP-8
RM
LTC1967应用
True RMS Digital Multimeters and Panel Meters
True RMS AC + DC Measurements
