LTC6943-微功率、精准仪表双开关电容器单元式部件
IC应用电路图
512人已加入
LTC6943描述
The LTC®6943 is a monolithic, charge-balanced, dual switched capacitor instrumentation building block. A pair of switches alternately connects an external capacitor to an input voltage and then connects the charged capacitor across an output port. The internal switches have a break-before-make action. An internal clock is provided and its frequency can be adjusted with an external capacitor. The LTC6943 can also be driven with an external CMOS clock.
The LTC6943, when used with low clock frequencies, provides ultra precision DC functions without requiring precise external components. Such functions are differential voltage to single-ended conversion, voltage inversion, voltage multiplication and division by 2, 3, 4, 5, etc.
The LTC6943 is manufactured using Linear Technology’s enhanced LTCMOSTM silicon gate process, and it is functionally compatible with the LTC1043.
LTC6943特点
Low Power, IS = 60µA(Max)
Robust, Latch Up Proof
Instrumentation Front End with 120dB CMRR
Precise, Charge-Balanced Switching
Operates from 5V to 18V
Internal or External Clock
Operates up to 5MHz Clock Rate
Two Independent Sections with One Clock
Tiny SSOP-16 Package
Typical Application
电容
电容
LTC6943封装
SSOP-16
电容
LTC6943应用
Ultra Precision Voltage Inverters, Multipliers and Dividers
V–F and F–V Converters
Sample-and-Hold
Current Sources
Precision Instrumentation Amplifiers
