LTC660-100mA CMOS Voltage Conv
IC应用电路图
512人已加入
LTC660描述
The LTC®660 is a monolithic CMOS switched-capacitor voltage converter. It performs supply voltage conversion from positive to negative from an input range of 1.5V to 5.5V, resulting in complementary output voltages of �1.5V to ±5.5V. It also performs a doubling at an input voltage range of 2.5V to 5.5V, resulting in a doubled output voltage of 5V to 11V. Only two external capacitors are needed for the charge pump and charge reservoir functions. The converter has an internal oscillator that can be overdriven by an external clock or slowed down when connected to a capacitor. The oscillator runs at a 10kHz frequency when unloaded. A higher frequency outside the audio band can also be obtained if the BOOST pin is tied to V+. The LTC660 contains an internal oscillator, divide-by-two, voltage level shifter and four power MOSFETs.
LTC660特点
Simple Conversion of 5V to -5V Supply
Output Drive: 100mA
ROUT: 6.5 ohms (0.65V Loss at 100mA)
Boost Pin (Pin 1) for Higher Switching Frequency
Inverting and Doubling Modes
Minimum Open Circuit Voltage Conversion Efficiency: 99%
Typical Power Conversion Efficiency with a 100mA Load: 88%
Easy to Use
Typical Application
LTC660封装
SO-8,N-8
LTC660应用
Conversion of 5V to ±5V Supplies
Inexpensive Negative Supplies
Data Acquisition Systems
High Current Upgrade to LTC1044 or 7660
