LTC1144-Switched-Capacitor Wid
IC应用电路图
512人已加入
LTC1144描述
The LTC1144 is a monolithic CMOS switched-capacitor voltage converter. It performs supply voltage conversion from positive to negative from an input range of 2V to 18V, resulting in complementary output voltages of -2V to -18V. Only two noncritical external capacitors are needed for the charge pump and charge reservoir functions. The converter has an internal oscillator that can be overdriven by an external clock or slowed down when connected to a capacitor. The oscillator runs at a 10kHz frequency when unloaded. A higher frequency outside the audio band can also be obtained if the Boost Pin is tied to V+ . The SHDN pin reduces supply current to 8µA and can be used to save power when the converter is not in use. The LTC1144 contains an internal oscillator, divide-by-two, voltage level shifter, and four power MOSFETs. A special logic circuit will prevent the power N-channel switch substrate from turning on.
LTC1144特点
Wide Operating Supply Voltage Range: 2V to 18V
Boost Pin (Pin 1) for Higher Switching Frequency
Simple Conversion of 15V to -15V Supply
Low Output Resistance: 120W Maximum
Power Shutdown to 8µA with SHDN
Open Circuit Voltage Conversion Efficiency: 99.9% Typical
Power Conversion Efficiency: 93% Typical
Easy to Use
Typical Application
LTC1144封装
SO-8
LTC1144应用
Conversion of 15V to ±15V Supplies
Inexpensive Negative Supplies
Data Acquisition Systems
High Voltage Upgrade to LTC1044 or 7660
Voltage Division and Multiplications
Automotive Applications
Battery Systems with Wall Adapter/Charger
