RH1009-2.5V Reference
IC应用电路图
512人已加入
RH1009描述
The RH1009 is a general purpose 2.5V shunt regulator diode designed to operate over a wide current range while maintaining good stability with time and temperature. The adjust terminal allows either temperature coefficient to be minimized or the reference voltage to be adjusted without changing the temperature coefficient. Because it operates as a shunt regulator it can be used equally well as a positive or negative reference.
The wafer lots are processed to Linear Technology's in-house Class S flow to yield circuits usable in stringent military applications.
RH1009特点
ABSOLUTE MAXIMUM RATINGS
Reverse Breakdown Current.......................20mA
Forward Current..............................10mA
Operating Temperature Range...........–55°C to 125°C
Storage Temperature Range...............–65°C to 150°C
Lead Temperature (Soldering, 10 sec........300°C
Typical Application
RH1009
RH1009封装
TO-46, FLATPAK-10 (Glass Sealed)
RH1009
