LT1007-Low Noise, High Speed P
IC应用电路图
512人已加入
LT1007描述
The LT1007/LT1037 series features the lowest noise performance available to date for monolithic operational amplifiers: 2.5nV/rtHz wideband noise (less than the noise of a 400 Ohm resistor), 1/f corner frequency of 2Hz and 60nV peakto- peak 0.1Hz to 10Hz noise. Low noise is combined with outstanding precision and speed specifications: 10µV offset voltage, 0.2µV/°C drift, 130dB common mode and power supply rejection, and 60MHz gain bandwidth product on the decompensated LT1037, which is stable for closed-loop gains of 5 or greater.
The voltage gain of the LT1007/LT1037 is an extremely high 20 million driving a 2k Ohm load and 12 million driving a 600 Ohm load to ±10V.
In the design, processing and testing of the device, particular attention has been paid to the optimization of the entire distribution of several key parameters. Consequently, the specifications of even the lowest cost grades (the LT1007C and the LT1037C) have been spectacularly improved compared to equivalent grades of competing amplifiers.
The sine wave generator application shown below utilizes the low noise and low distortion characteristics of the LT1037.
LT1007特点
Guaranteed 4.5 nV/Root-Hz 10Hz noise
Guaranteed 3.8 nV/Root-Hz 1kHz noise
0.1Hz to 10Hz noise, 60nVP-P, Typical
Guaranteed 7 Million Min Voltage Gain, RL = 2k
Guaranteed 3 Million Min Voltage Gain, RL = 600 Ohm
Guaranteed 25µV Max Offset Voltage
Guaranteed 0.6µV/°C Max Drift with Temperature
Guaranteed 11V/µsec Min Slew Rate (LT1037)
Guaranteed 117 dB Min CMRR
Typical Application
LT1007封装
DIP-8,SO-8
LT1007
LT1007应用
Low Noise Signal Processing
Microvolt Accuracy Threshold Detection
Strain Gauge Amplifiers
Direct Coupled Audio Gain Stages
Sine Wave Generators
Tape Head Preamplifiers
Microphone Preamplifiers
