MAX44007 Low-Power Digital Amb
新品快讯
30人已加入
MAX44007 Low-Power Digital Ambient Light Sensor with Enhanced Sensitivity
概述
The MAX44007 ambient light sensor features an I²C digital output that is ideal for a number of portable applications such as smartphones, notebooks, and industrial sensors. At less than 1µA operating current, it is the lowest power ambient light sensor in the industry and features an ultra-wide 22-bit dynamic range from 0.025 lux to 104,444 lux.
Low-light operation allows easy operation in dark glass applications.
The on-chip photodiode's spectral response is optimized to mimic the human eye's perception of ambient light and incorporates IR and UV blocking capability. The adaptive gain block automatically selects the correct lux range to optimize the counts/lux.
The IC includes two I²C slave address options: 1011 010x and 1011 011x.
The IC is designed to operate from a 1.7V to 3.6V supply voltage range and consumes only 0.65µA in full operation. It is available in a small, 2mm x 2mm x 0.6mm UTDFN-Opto package.
关键特性
  • Wide 0.025 Lux to 104,444 Lux Range
  • Small, 2mm x 2mm x 0.6mm UTDFN-Opto
  • VCC = 1.7V to 3.6V
  • ICC = 0.65µA Operating Current
  • -40°C to +85°C Temperature Range
  • Improved Sensitivity Behind Dark Glass
应用/使用
蜂窝电话/智能电话
数字照明管理
便携式设备
安全系统
平板PC/笔记本电脑
TV/投影仪/显示器
  • 相关推荐
  • 热点推荐
  • Sensor
