不依赖外部库的情况下,限流算法有什么实现的思路?本文介绍了3种实现限流的方式。
package mainimport ("fmt""sync""time")// 每个请求来了,把需要执行的业务逻辑封装成Task,放入木桶,等待worker取出执行type Task struct {handler func() Result // worker从木桶中取出请求对象后要执行的业务逻辑函数resChan chan Result // 等待worker执行并返回结果的channeltaskID int}// 封装业务逻辑的执行结果type Result struct {}// 模拟业务逻辑的函数func handler() Result {time.Sleep(300 * time.Millisecond)return Result{}}func NewTask(id int) Task {return Task{handler: handler,resChan: make(chan Result),taskID: id,}}// 漏桶type LeakyBucket struct {BucketSize int // 木桶的大小NumWorker int // 同时从木桶中获取任务执行的worker数量bucket chan Task // 存方任务的木桶}func NewLeakyBucket(bucketSize int, numWorker int) *LeakyBucket {return &LeakyBucket{BucketSize: bucketSize,NumWorker: numWorker,bucket: make(chan Task, bucketSize),}}func (b *LeakyBucket) validate(task Task) bool {// 如果木桶已经满了,返回falseselect {case b.bucket <- task:default:fmt.Printf("request[id=%d] is refused ", task.taskID)return false}// 等待worker执行<-task.resChanfmt.Printf("request[id=%d] is run ", task.taskID)return true}func (b *LeakyBucket) Start() {// 开启worker从木桶拉取任务执行go func() {for i := 0; i < b.NumWorker; i++ {go func() {for {task := <-b.bucketresult := task.handler()task.resChan <- result}}()}}()}func main() {bucket := NewLeakyBucket(10, 4)bucket.Start()var wg sync.WaitGroupfor i := 0; i < 20; i++ {wg.Add(1)go func(id int) {defer wg.Done()task := NewTask(id)bucket.validate(task)}(i)}wg.Wait()}
package mainimport ("fmt""sync""time")// 并发访问同一个user_id/ip的记录需要上锁var recordMu map[string]*sync.RWMutexfunc init() {recordMu = make(map[string]*sync.RWMutex)}func max(a, b int) int {if a > b {return a}return b}type TokenBucket struct {BucketSize int // 木桶内的容量:最多可以存放多少个令牌TokenRate time.Duration // 多长时间生成一个令牌records map[string]*record // 报错user_id/ip的访问记录}// 上次访问时的时间戳和令牌数type record struct {last time.Timetoken int}func NewTokenBucket(bucketSize int, tokenRate time.Duration) *TokenBucket {return &TokenBucket{BucketSize: bucketSize,TokenRate: tokenRate,records: make(map[string]*record),}}func (t *TokenBucket) getUidOrIp() string {// 获取请求用户的user_id或者ip地址return "127.0.0.1"}// 获取这个user_id/ip上次访问时的时间戳和令牌数func (t *TokenBucket) getRecord(uidOrIp string) *record {if r, ok := t.records[uidOrIp]; ok {return r}return &record{}}// 保存user_id/ip最近一次请求时的时间戳和令牌数量func (t *TokenBucket) storeRecord(uidOrIp string, r *record) {t.records[uidOrIp] = r}// 验证是否能获取一个令牌func (t *TokenBucket) validate(uidOrIp string) bool {// 并发修改同一个用户的记录上写锁rl, ok := recordMu[uidOrIp]if !ok {var mu sync.RWMutexrl = &murecordMu[uidOrIp] = rl}rl.Lock()defer rl.Unlock()r := t.getRecord(uidOrIp)now := time.Now()if r.last.IsZero() {// 第一次访问初始化为最大令牌数r.last, r.token = now, t.BucketSize} else {if r.last.Add(t.TokenRate).Before(now) {// 如果与上次请求的间隔超过了token rate// 则增加令牌,更新lastr.token += max(int(now.Sub(r.last) / t.TokenRate), t.BucketSize)r.last = now}}var result boolif r.token > 0 {// 如果令牌数大于1,取走一个令牌,validate结果为truer.token--result = true}// 保存最新的recordt.storeRecord(uidOrIp, r)return result}// 返回是否被限流func (t *TokenBucket) IsLimited() bool {return !t.validate(t.getUidOrIp())}func main() {tokenBucket := NewTokenBucket(5, 100*time.Millisecond)for i := 0; i< 6; i++ {fmt.Println(tokenBucket.IsLimited())}time.Sleep(100 * time.Millisecond)fmt.Println(tokenBucket.IsLimited())}
package mainimport ("fmt""sync""time")var winMu map[string]*sync.RWMutexfunc init() {winMu = make(map[string]*sync.RWMutex)}type timeSlot struct {timestamp time.Time // 这个timeSlot的时间起点count int // 落在这个timeSlot内的请求数}func countReq(win []*timeSlot) int {var count intfor _, ts := range win {count += ts.count}return count}type SlidingWindowLimiter struct {SlotDuration time.Duration // time slot的长度WinDuration time.Duration // sliding window的长度numSlots int // window内最多有多少个slotwindows map[string][]*timeSlotmaxReq int // win duration内允许的最大请求数}func NewSliding(slotDuration time.Duration, winDuration time.Duration, maxReq int) *SlidingWindowLimiter {return &SlidingWindowLimiter{SlotDuration: slotDuration,WinDuration: winDuration,numSlots: int(winDuration / slotDuration),windows: make(map[string][]*timeSlot),maxReq: maxReq,}}// 获取user_id/ip的时间窗口func (l *SlidingWindowLimiter) getWindow(uidOrIp string) []*timeSlot {win, ok := l.windows[uidOrIp]if !ok {win = make([]*timeSlot, 0, l.numSlots)}return win}func (l *SlidingWindowLimiter) storeWindow(uidOrIp string, win []*timeSlot) {l.windows[uidOrIp] = win}func (l *SlidingWindowLimiter) validate(uidOrIp string) bool {// 同一user_id/ip并发安全mu, ok := winMu[uidOrIp]if !ok {var m sync.RWMutexmu = &mwinMu[uidOrIp] = mu}mu.Lock()defer mu.Unlock()win := l.getWindow(uidOrIp)now := time.Now()// 已经过期的time slot移出时间窗timeoutOffset := -1for i, ts := range win {if ts.timestamp.Add(l.WinDuration).After(now) {break}timeoutOffset = i}if timeoutOffset > -1 {win = win[timeoutOffset+1:]}// 判断请求是否超限var result boolif countReq(win) < l.maxReq {result = true}// 记录这次的请求数var lastSlot *timeSlotif len(win) > 0 {lastSlot = win[len(win)-1]if lastSlot.timestamp.Add(l.SlotDuration).Before(now) {lastSlot = &timeSlot{timestamp: now, count: 1}win = append(win, lastSlot)} else {lastSlot.count++}} else {lastSlot = &timeSlot{timestamp: now, count: 1}win = append(win, lastSlot)}l.storeWindow(uidOrIp, win)return result}func (l *SlidingWindowLimiter) getUidOrIp() string {return "127.0.0.1"}func (l *SlidingWindowLimiter) IsLimited() bool {return !l.validate(l.getUidOrIp())}func main() {limiter := NewSliding(100*time.Millisecond, time.Second, 10)for i := 0; i < 5; i++ {fmt.Println(limiter.IsLimited())}time.Sleep(100 * time.Millisecond)for i := 0; i < 5; i++ {fmt.Println(limiter.IsLimited())}fmt.Println(limiter.IsLimited())for _, v := range limiter.windows[limiter.getUidOrIp()] {fmt.Println(v.timestamp, v.count)}fmt.Println("a thousand years later...")time.Sleep(time.Second)for i := 0; i < 7; i++ {fmt.Println(limiter.IsLimited())}for _, v := range limiter.windows[limiter.getUidOrIp()] {fmt.Println(v.timestamp, v.count)}}
文章出处:【微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
