FluentMybatis提供了哪些便利呢?
使用fluent mybatis可以不用写具体的xml文件,通过java api可以构造出比较复杂的业务sql语句,做到代码逻辑和sql逻辑的合一。不再需要在Dao中组装查询或更新操作,在xml或mapper中再组装参数。那对比原生Mybatis, Mybatis Plus或者其他框架,FluentMybatis提供了哪些便利呢?
场景需求设置
我们通过一个比较典型的业务需求来具体实现和对比下,假如有学生成绩表结构如下:
create table `student_score` (     id           bigint auto_increment comment '主键ID' primary key,     student_id bigint            not null comment '学号',     gender_man tinyint default 0 not null comment '性别, 0:女; 1:男',     school_term int               null comment '学期',     subject varchar(30) null comment '学科',     score int               null comment '成绩',     gmt_create datetime not null comment '记录创建时间',     gmt_modified datetime not null comment '记录最后修改时间',     is_deleted tinyint default 0 not null comment '逻辑删除标识' ) engine = InnoDB default charset=utf8;
现在有需求:
统计2000年三门学科('英语', '数学', '语文')及格分数按学期,学科统计最低分,最高分和平均分,且样本数需要大于1条,统计结果按学期和学科排序
我们可以写SQL语句如下:
select school_term,        subject,        count(score) as count,        min(score) as min_score,        max(score) as max_score,        avg(score) as max_score from student_score where school_term >= 2000   and subject in ('英语', '数学', '语文')   and score >= 60   and is_deleted = 0 group by school_term, subject having count(score) > 1 order by school_term, subject;
那上面的需求,分别用fluent mybatis, 原生mybatis 和 Mybatis plus来实现一番。
三者对比
使用fluent mybatis 来实现上面的功能
Fluent
我们可以看到fluent api的能力,以及IDE对代码的渲染效果。
代码:https://gitee.com/fluent-mybatis/fluent-mybatis-docs/tree/master/spring-boot-demo/
换成mybatis原生实现效果
1. 定义Mapper接口
public interface MyStudentScoreMapper {     ListString, Object>> summaryScore(SummaryQuery paras); }
 2. 定义接口需要用到的参数实体 SummaryQuery
		@Data @Accessors(chain = true) public class SummaryQuery {     private Integer schoolTerm;     private List<String> subjects;     private Integer score;     private Integer minCount; }3. 定义实现业务逻辑的mapper xml文件
		<select id="summaryScore" resultType="map" parameterType="cn.org.fluent.mybatis.springboot.demo.mapper.SummaryQuery">     select school_term,     subject,     count(score) as count,     min(score) as min_score,     max(score) as max_score,     avg(score) as max_score     from student_score     where school_term >= #{schoolTerm}     and subject in     <foreach collection="subjects" item="item" open="(" close=")" separator=",">         #{item}     foreach>     and score >= #{score}     and is_deleted = 0     group by school_term, subject     having count(score) > #{minCount}     order by school_term, subject select>4. 实现业务接口(这里是测试类, 实际应用中应该对应Dao类)
		@RunWith(SpringRunner.class) @SpringBootTest(classes = QuickStartApplication.class) public class MybatisDemo {     @Autowired     private MyStudentScoreMapper mapper;     @Test     public void mybatis_demo() {                  SummaryQuery paras = new SummaryQuery()             .setSchoolTerm(2000)             .setSubjects(Arrays.asList("英语", "数学", "语文"))             .setScore(60)             .setMinCount(1);         ListString, Object>> summary = mapper.summaryScore(paras);         System.out.println(summary);     } }总之,直接使用mybatis,实现步骤还是相当的繁琐,效率太低。那换成mybatis plus的效果怎样呢?
换成mybatis plus实现效果
mybatis plus的实现比mybatis会简单比较多,实现效果如下:
Fluent
如红框圈出的,写mybatis plus实现用到了比较多字符串的硬编码(可以用Entity的get lambda方法部分代替字符串编码)。字符串的硬编码,会给开发同学造成不小的使用门槛,个人觉的主要有2点:1. 字段名称的记忆和敲码困难2. Entity属性跟随数据库字段发生变更后的运行时错误其他框架,比如TkMybatis在封装和易用性上比mybatis plus要弱,就不再比较了。生成代码编码比较
fluent mybatis生成代码设置
		public class AppEntityGenerator {     static final String url = "jdbc//localhost:3306/fluent_mybatis_demo?useSSL=false&useUnicode=true&characterEncoding=utf-8";     public static void main(String[] args) {         FileGenerator.build(Abc.class);     }     @Tables(         /** 数据库连接信息 **/         url = url, username = "root", password = "password",         /** Entity类parent package路径 **/         basePack = "cn.org.fluent.mybatis.springboot.demo",         /** Entity代码源目录 **/         srcDir = "spring-boot-demo/src/main/java",         /** Dao代码源目录 **/         daoDir = "spring-boot-demo/src/main/java",         /** 如果表定义记录创建,记录修改,逻辑删除字段 **/         gmtCreated = "gmt_create", gmtModified = "gmt_modified", logicDeleted = "is_deleted",         /** 需要生成文件的表 ( 表名称:对应的Entity名称 ) **/         tables = @Table(value = {"student_score"})     )     static class Abc {     } }
mybatis plus代码生成设置
		public class CodeGenerator {     static String dbUrl = "jdbc//localhost:3306/fluent_mybatis_demo?useSSL=false&useUnicode=true&characterEncoding=utf-8";     @Test     public void generateCode() {         GlobalConfig config = new GlobalConfig();         DataSourceConfig dataSourceConfig = new DataSourceConfig();         dataSourceConfig.setDbType(DbType.MYSQL)             .setUrl(dbUrl)             .setUsername("root")             .setPassword("password")             .setDriverName(Driver.class.getName());         StrategyConfig strategyConfig = new StrategyConfig();         strategyConfig             .setCapitalMode(true)             .setEntityLombokModel(false)             .setNaming(NamingStrategy.underline_to_camel)             .setColumnNaming(NamingStrategy.underline_to_camel)             .setEntityTableFieldAnnotationEnable(true)             .setFieldPrefix(new String[]{"test_"})             .setInclude(new String[]{"student_score"})             .setLogicDeleteFieldName("is_deleted")             .setTableFillList(Arrays.asList(                 new TableFill("gmt_create", FieldFill.INSERT),                 new TableFill("gmt_modified", FieldFill.INSERT_UPDATE)));         config             .setActiveRecord(false)             .setIdType(IdType.AUTO)             .setOutputDir(System.getProperty("user.dir") + "/src/main/java/")             .setFileOverride(true);         new AutoGenerator().setGlobalConfig(config)             .setDataSource(dataSourceConfig)             .setStrategy(strategyConfig)             .setPackageInfo(                 new PackageConfig()                     .setParent("com.mp.demo")                     .setController("controller")                     .setEntity("entity")             ).execute();     } }
Fluent
看完3个框架对同一个功能点的实现, 各位看官肯定会有自己的判断,笔者这里也总结了一份比较。Fluent
审核编辑 :李倩
