MAX197的带液晶显示源程序
集成电路
75人已加入
include
#include
#include
#define uint unsigned int
#define uchar unsigned char
#define max197 XBYTE[0xefff]
sbit EN=P2^0;
sbit RS=P2^1;
sbit CS=P2^2;
sbit HBEN=P2^3;
sbit duan=P2^6;
uchar templ,temph,flag;
float dianya;
uint temp,temp1[25];
unsigned long voltage;
void delay(uint i)
  while(i--);
void delay1(uint z)
 int x,y;
 for(x=z;x>0;x--)
  for(y=114;y>0;y--);
void write_com(uchar com)
 RS=0;
 P1=com;
 delay1(5);
 EN=1;
 delay1(5);
 EN=0;
void write_data(uchar date)
 RS=1;
 P1=date;
 delay1(5);
 EN=1;
 delay1(5);
 EN=0;
void initial()
  EN=0;
  write_com(0x38);
  write_com(0x0c);
  write_com(0x06);
  write_com(0x01);
void printc(uchar lcd_data)          //输出一个字符到LCD
    write_data(lcd_data);
void prints(uchar *lcd_string)       //输出一个字符串到LCD
 uchar i=0;
 while(lcd_string[i]!=0x00)
   write_data(lcd_string[i]);
   i++;
void setPosition(uchar x)            //LCD光标定位到x处
  write_com(0x80+x);
uchar TempBuffer[7];
void IntToStr(uint temp, uchar *str, uchar n)
 uchar a[7]; char i, j;    //取得整数值到数组
 dianya=temp/4096.0;
 voltage=dianya*100000;
 a[0]=voltage/10000;
 a[1]=voltage%10000/1000;
 a[2]=voltage%1000/100;
 a[3]=voltage%100/10;
 a[4]=voltage%10;
 for(i=0; i<5; i++)         //转成ASCII码
  a[i]=a[i]+'0';
 for(i=0; a[i]=='0' && i<=5; i++);
 for(j=5-n; j   { *str=' ';  str++; }
 for(; i<5; i++)
  { *str=a[i]; str++; }  //加入有效的数字
 *str='\0';
void initial_max197()
        //uchar *AD;
       // AD=&max197;
        //单片机初始化
  EA=1;
  IT1=1;
  EX1=1;
  duan=0;
        //初始化MAX197
        //*AD=0x40;
void main()
 uchar i;
 initial();
 initial_max197();
 //CS=0;
 max197=0x40;
 setPosition(0x00);
 prints("The voltage is :");
 while(1)
  //采集15次;
    for(i=0;i<15;i++)
   flag=0;
   max197=0x40;
   while(!flag);
   HBEN=1;
   temph=max197;
   _nop_();
   HBEN=0;
   templ=max197;
   temp=temph;
   temp<<=8;
   temp1[i]=temp|templ;
  temp=0;
  for(i=0;i<15;i++)
   temp=temp+temp1[i];
  temp=temp/15;//取平均值
  IntToStr(temp,&TempBuffer[0],5);
  setPosition(0x40);
  printc(TempBuffer[0]);
  printc(TempBuffer[1]);
  printc('.');
  printc(TempBuffer[2]);
  printc(TempBuffer[3]);
  printc(TempBuffer[4]);
  prints("mv");
  delay1(500);
  max197=0x40;
void convert() interrupt 2 using 2
 flag=1;
