Python 天然支持多态,但使用 dispatch 可以让你的代码更加容易阅读。
安装:
pip install multipledispatch
使用:
>>> from multipledispatch import dispatch
>>> @dispatch(int, int)
... def add(x, y):
... return x + y
>>> @dispatch(object, object)
... def add(x, y):
... return "%s + %s" % (x, y)
>>> add(1, 2)
3
>>> add(1, 'hello')
'1 + hello'
click 可以很方便地让你实现命令行工具。
安装:
pip install click
使用:demo2.py :
import click
@click.command()
@click.option('--count', default=1, help='Number of greetings.')
@click.option('--name', prompt='Your name',
help='The person to greet.')
def hello(count, name):
"""Simple program that greets NAME for a total of COUNT times."""
for x in range(count):
click.echo(f"Hello {name}!")
if __name__ == '__main__':
hello()
运行结果:
❯ python demo2.py --count=3 --name=joih
Hello joih!
Hello joih!
Hello joih!
Your name: somenzz
Hello somenzz!
Hello somenzz!
Hello somenzz!
分布式的任务队列,非 Celery 莫属。
from celery import Celery
app = Celery('tasks', broker='pyamqp://guest@localhost//')
@app.task
def add(x, y):
return x + y
这个相信大家在使用别的包时都遇到过,当要下线一个老版本的函数的时候就可以使用这个装饰器。
安装:
pip install Deprecated
使用:demo4.py
from deprecated import deprecated
@deprecated ("This function is deprecated, please do not use it")
def func1():
pass
func1()
运行效果如下:
❯ python demo4.py
demo4.py:6: DeprecationWarning: Call to deprecated function (or staticmethod) func1. (This function is deprecated, please do not use it)
func1()
安装:
pip install deco
使用 DECO 就像在 Python 程序中查找或创建两个函数一样简单。我们可以用 @concurrent 装饰需要并行运行的函数,用 @synchronized 装饰调用并行函数的函数,使用举例:
from deco import concurrent, synchronized
@concurrent # We add this for the concurrent function
def process_url(url, data):
#Does some work which takes a while
return result
@synchronized # And we add this for the function which calls the concurrent function
def process_data_set(data):
results = {}
for url in urls:
results[url] = process_url(url, data)
return results
缓存工具
安装:
pip install cachetools
使用:
from cachetools import cached, LRUCache, TTLCache
# speed up calculating Fibonacci numbers with dynamic programming
@cached(cache={})
def fib(n):
return n if n < 2 else fib(n - 1) + fib(n - 2)
# cache least recently used Python Enhancement Proposals
@cached(cache=LRUCache(maxsize=32))
def get_pep(num):
url = 'http://www.python.org/dev/peps/pep-%04d/' % num
with urllib.request.urlopen(url) as s:
return s.read()
# cache weather data for no longer than ten minutes
@cached(cache=TTLCache(maxsize=1024, ttl=600))
def get_weather(place):
return owm.weather_at_place(place).get_weather()
重试装饰器,支持各种各样的重试需求。
安装:
pip install tenacity
使用:
import random
from tenacity import retry
@retry
def do_something_unreliable():
if random.randint(0, 10) > 1:
raise IOError("Broken sauce, everything is hosed!!!111one")
else:
return "Awesome sauce!"
@retry(stop=stop_after_attempt(7))
def stop_after_7_attempts():
print("Stopping after 7 attempts")
raise Exception
@retry(stop=stop_after_delay(10))
def stop_after_10_s():
print("Stopping after 10 seconds")
raise Exception
@retry(stop=(stop_after_delay(10) | stop_after_attempt(5)))
def stop_after_10_s_or_5_retries():
print("Stopping after 10 seconds or 5 retries")
raise Exception
审核编辑:符乾江
