SuspensionEntrance 是一个仿微信新版浮窗入口功能。
使用方法
pod SuspensionExtrance ~> 0.1.0 // 使用podfile方式引入
@implementation BaseNavigationController
- (void)viewDidLoad {
[super viewDidLoad];
// 在自定义的navigationController中 设置代理, 如果已经使用了代理,
self.delegate = [SuspensionEntrance shared];
// 关闭系统返回手势
self.interactivePopGestureRecognizer.enabled = NO;
@end
// 对于可以作为入口界面的Controller,实现SEItem协议
@interface EntranceViewController : UIViewController
@property (copy , nonatomic) NSString *entranceTitle;
@property (copy , nonatomic, nullable) NSURL *entranceIconUrl;
@property (copy , nonatomic, nullable) NSDictionary *entranceUserInfo;
@end
// 并实现下列构造方法, !!! 如果不实现则无法进行序列化存储
+ (instancetype)entranceWithItem:(id)item {
EntranceViewController *controller = [[EntranceViewController alloc] initWithNibName:nil bundle:nil];
controller.entranceTitle = item.entranceTitle;
controller.entranceIconUrl = item.entranceIconUrl;
controller.entranceUserInfo = item.entranceUserInfo;
return controller;
一般情况下, 我们自己项目内都会使用自定义返回手势, 并且已经设置了代理, 那可以采用下列的方式进行对接
// 在对应的代理方法里面调用
- (void)navigationController:(UINavigationController *)navigationController willShowViewController:(UIViewController *)viewController animated:(BOOL)animated {
[[SuspensionEntrance shared] navigationController:navigationController willShowViewController:viewController animated:animated];
- (void)navigationController:(UINavigationController *)navigationController didShowViewController:(UIViewController *)viewController animated:(BOOL)animated {
[[SuspensionEntrance shared] navigationController:navigationController didShowViewController:viewController animated:animated];
- (id)navigationController:(UINavigationController *)navigationController interactionControllerForAnimationController:(id)animationController {
return [[SuspensionEntrance shared] navigationController:navigationController interactionControllerForAnimationController:animationController];
- (id)navigationController:(UINavigationController *)navigationController animationControllerForOperation:(UINavigationControllerOperation)operation fromViewController:(UIViewController *)fromVC toViewController:(UIViewController *)toVC {
return [[SuspensionEntrance shared] navigationController:navigationController animationControllerForOperation:operation fromViewController:fromVC toViewController:toVC];
// 然后同上面一步, 一样实现SEItem协议, 需要注意的事, 需要手动关闭自定义返回手势, 以避免手势冲突
// 以集成了 forkingdog/FDFullscreenPopGesture(https://github.com/forkingdog/FDFullscreenPopGesture) 为例, 添加下列方法
- (void)fd_interactivePopDisabled { return YES; }
