使用LocalDate和LocalDateTime
史蒂夫.乔布斯说,”复杂的终极境界是简单“,同样的优雅的代码一定是精简明了,可读性好。
LocalDate精确到日期,LocalDateTime精确到时分秒。优化前14行代码
  1. try {
  2.    SimpleDateFormat sdfDay = new SimpleDateFormat("yyyy-MM-dd");
  3.    SimpleDateFormat sdfMins = new SimpleDateFormat("yyyy-MM-dd HHss");
  4.    Date now = new Date();
  5.    String today = sdfDay.format(now);
  6.    String waterStart = today + " 0300";
  7.    String waterEnd = today + " 0400";
  8.    Date waterStartTime = sdfMins.parse(waterStart);
  9.    Date waterEndTime = sdfMins.parse(waterEnd);
  10. } catch (ParseException pe) {
  11.    return XX;
  12. }
优化后3行代码
  1. LocalDateTime now = LocalDateTime.now();
  2. LocalDateTime waterStart = LocalDateTime.of(now.getYear(), now.getMonth(),now.getDayOfMonth(),3,0);
  3. LocalDateTime waterEndTime =LocalDateTime.of(now.getYear(), now.getMonth(),now.getDayOfMonth(),4,0);
默认值使用Optional
优化前五行
  1. if (null == status) {
  2.    param.put("status", new ArrayList<String>());
  3. } else {
  4.    param.put("status", status);
  5. }
优化后一行,使用JDK8的Optional
  1. Optional.ofNullable(status).orElse(new ArrayList<String>());
如果是字符串可以用
  1. StringUtils.defaultIfEmpty(status,"")
字符串累加
字符串只要不在for循环里累加,可以直接用+号,因为编译成字节码后会变成StringBuilder,如果在for循环里面用+号会生成多个StringBuilder,所以在for循环里累加最好在循环外创建StringBuilder。优化前五行
  1. StringBuffer sblog = new StringBuffer();
  2. sblog.append("waterDriven|sellerId=");
  3. sblog.append(request.getSellerTaobaoId());
  4. sblog.append("|result=");
  5. sblog.append(isSuccess);
优化后一行
  1. String sblog="waterDriven|sellerId="+request.getSellerTaobaoId()+"|result="+isSuccess;
以上场景用逗号和等号连接数据,使用GUAVA的Joiner更精简,可读性更好
  1. String sblog=Joiner.on("|").withKeyValueSeparator("=").join(ImmutableMap.of("sellerId", request.getSellerTaobaoId(), "result", isSuccess))
LIST TO MAP
优化前4行
  1. Map<String, String> AssetsMetaIdMap = Maps.newHashMap();
  2. for (AssetsInfoBO assetsInfoBO : request.getAssetsCollectionList()) {
  3.    AssetsMetaIdMap.put(assetsInfoBO.getAssetMetadataId(), assetsInfoBO.getAssetMetadataId());
  4. }
优化后1行
  1. Map<String, String> AssetsMetaIdMap = request.getAssetsCollectionList().stream().collect(Collectors.toMap(Hosting::getAssetMetadataId, Hosting::getAssetMetadataId));
如果key重复会抛出异常
  1. Exception in thread "main" java.lang.IllegalStateException: Duplicate key 80000
减少不需要的判断
优化前5行
  1. String requestId = null;
  2. if (null != request.getExtData()) {
  3.    requestId = request.getExtDataValue(REQUEST_ID_KEY);
  4. }
  5. return requestId;
优化后1行
  1. return request.getExtDataValue(REQUEST_ID_KEY);
去掉else
优化前5行
  1. if (null != result && StringUtils.isNotBlank(no)) {
  2.     return no;
  3. } else {
  4.     throw new RuntimeException("XX");
  5. }
优化后4行
  2.     return no;
  3. }
不要返回布尔
优化前5行
  1. if ("true".equalsIgnoreCase(value.toString())) {
  2.    invoke = true;
  3. } else {
  4.    invoke = false;
  5. }
优化后一行
  1. invoke = "true".equalsIgnoreCase(value.toString());
使用级联
优化前5行
  1. ParamBO paramBO = new ParamBO();
  2. paramBO.setId(1);
  3. paramBO.setName(”ifeve“);
  4. paramBO.setOld(7);
优化后1行
  1. new ParamBO().withId(1).withName("ifeve").withOld(7);
-End-
审核编辑 :李倩
