德州仪器推INA128-HT高温精密低功耗仪表放大器
新品快讯
30人已加入
INA128-HT 高温精密低功耗仪表放大器 Precision Low Power Instrumentation Amplifiers.
INA128-HT说明
The INA128 and INA129 are low power, general purpose instrumentation amplifiers offering excellent accuracy. The versatile three operational amplifier design and small size make them ideal for a wide range of applications. Current-feedback input circuitry provides wide bandwidth even at high gain.
A single external resistor sets any gain from 1 to 10,000. The INA128 provides an industry-standard gain equation; the INA129 gain equation is compatible with the AD620.
The INA128/INA129 is laser trimmed for very low offset voltage (50 µV) and high common-mode rejection (93 dB at G ≥ 100). It operates with power supplies as low as ±2.25 V, and quiescent current of 2 mA - typically. Internal input protection can withstand up to ±40 V without damage.
INA128-HT特性
Low Offset Voltage
Low Input Bias Current: 50 nA Typ
High CMR: 95 dB Typ
Inputs Protected to ±40 V
Wide Supply Range: ±2.25 V to ±18 V
Low Quiescent Current: 2 mA Typ
APPLICATIONS
Bridge Amplifier
Thermocouple Amplifier
RTD Sensor Amplifier
Medical Instrumentation
Data Acquisition
SUPPORTS EXTREME TEMPERATURE APPLICATIONS
Controlled Baseline
One Assembly/Test Site
One Fabrication Site
Available in Extreme (–55°C/210°C)
Temperature Range(1)
Extended Product Life Cycle
Extended Product-Change Notification
Product Traceability
