TI推THS770012具10dB-13dB可选增益的全差动ADC驱动器放大器
新品快讯
29人已加入
THS770012具有从10dB到13dB的可选增益的高速全差动ADC驱动器放大器
THS770012说明
The THS770012 is a wideband, fully-differential amplifier, with adjustable gain range from +10dB to +13.7dB (with external components). It is designed and optimized specifically for driving 16-bit analog-to-digital converters (ADCs) at input frequencies up to 130MHz, and 14-bit ADCs at input frequencies up to 200MHz. This device provides high bandwidth, high-voltage output with low distortion and low noise, critical in high-speed data acquisition systems that require very high dynamic range, such as wireless base stations and test and measurement applications. This device also makes an excellent differential amplifier for general-purpose, high-speed differential signal chain and short line driver applications.
THS770012特性
900MHz Bandwidth at Gain of +10dB
3300V/µs Slew Rate, VOUT = 2V step
Adjustable Gain: +10dB to +13.7dB
IMD3: –100dBc, VOUT = 2VPP, RL = 400,
f = 100MHz
OIP3: 47dBm, f = 100MHz
Noise Figure: 10.7 dB, f = 100MHz
APPLICATIONS
14-/16-Bit ADC Driver
ADC Driver for Wireless Base Station Signal Chains:
GSM, WCDMA, MC-GSM, LTE
ADC Driver for High Dynamic Range Test
and Measurement Equipment
PowerPAD is a trademark of Texas Instruments.
All other trademarks are the property of their respective owners.
THS770012功能方框图
THS770012
