如何使用Spring构建REST服务(二) 书接上文⬆⬆⬆
要使用 Web 层次包装您的存储库,您必须使用 Spring MVC。多亏了 Spring Boot,代码基础设施很少。相反,我们可以专注于行动:
nonrest/src/main/java/payroll/EmployeeController.java
package payroll;
import java.util.List;
import org.springframework.web.bind.annotation.DeleteMapping;
import org.springframework.web.bind.annotation.GetMapping;
import org.springframework.web.bind.annotation.PathVariable;
import org.springframework.web.bind.annotation.PostMapping;
import org.springframework.web.bind.annotation.PutMapping;
import org.springframework.web.bind.annotation.RequestBody;
import org.springframework.web.bind.annotation.RestController;
@RestController
class EmployeeController {
private final EmployeeRepository repository;
EmployeeController(EmployeeRepository repository) {
this.repository = repository;
// Aggregate root
// tag::get-aggregate-root[]
@GetMapping("/employees")
List all() {
return repository.findAll();
// end::get-aggregate-root[]
@PostMapping("/employees")
Employee newEmployee(@RequestBody Employee newEmployee) {
return repository.save(newEmployee);
// Single item
@GetMapping("/employees/{id}")
Employee one(@PathVariable Long id) {
return repository.findById(id)
.orElseThrow(() -> new EmployeeNotFoundException(id));
@PutMapping("/employees/{id}")
Employee replaceEmployee(@RequestBody Employee newEmployee, @PathVariable Long id) {
.map(employee -> {
employee.setName(newEmployee.getName());
employee.setRole(newEmployee.getRole());
return repository.save(employee);
.orElseGet(() -> {
newEmployee.setId(id);
@DeleteMapping("/employees/{id}")
void deleteEmployee(@PathVariable Long id) {
repository.deleteById(id);
nonrest/src/main/java/payroll/EmployeeNotFoundException.java
package payroll;
class EmployeeNotFoundException extends RuntimeException {
EmployeeNotFoundException(Long id) {
super("Could not find employee " + id);
当EmployeeNotFoundException抛出 an 时,Spring MVC 配置的这个额外花絮用于呈现HTTP 404:
nonrest/src/main/java/payroll/EmployeeNotFoundAdvice.java
package payroll;
import org.springframework.http.HttpStatus;
import org.springframework.web.bind.annotation.ControllerAdvice;
import org.springframework.web.bind.annotation.ExceptionHandler;
import org.springframework.web.bind.annotation.ResponseBody;
import org.springframework.web.bind.annotation.ResponseStatus;
@ControllerAdvice
class EmployeeNotFoundAdvice {
@ResponseBody
@ExceptionHandler(EmployeeNotFoundException.class)
@ResponseStatus(HttpStatus.NOT_FOUND)
String employeeNotFoundHandler(EmployeeNotFoundException ex) {
return ex.getMessage();
要启动应用程序,请右键单击其中并从 IDEpublic static void main中PayRollApplication选择运行,或者:
Spring Initializr 使用 maven 包装器,所以输入:
$ ./mvnw clean spring-boot:run
或者使用您安装的 Maven 版本输入:
$ mvn clean spring-boot:run
当应用程序启动时,我们可以立即对其进行询。
$ curl -v localhost:8080/员工
这将产生:
* 尝试 ::1...* TCP_NODELAY 设置* 连接到 localhost (::1) 端口 8080 (#0)> GET /员工 HTTP/1.1> 主机:本地主机:8080> 用户代理:curl/7.54.0> 接受:*/*>< HTTP/1.1 200< 内容类型:application/json;charset=UTF-8< 传输编码:分块< 日期:格林威治标准时间 2018 年 8 月 9 日星期四 17:58:00<* 连接 #0 到主机 localhost 保持不变[{"id":1,"name":"Bilbo Baggins","role":"窃贼"},{"id":2,"name":"Frodo Baggins","角色":"小偷"} ]
在这里,您可以看到压缩格式的预加载数据。
如果您尝试查询一个不存在的用户......
$ curl -v localhost:8080/employees/99
你得到…
* 尝试 ::1...* TCP_NODELAY 设置* 连接到 localhost (::1) 端口 8080 (#0)> 获取 /employees/99 HTTP/1.1> 主机:本地主机:8080> 用户代理:curl/7.54.0> 接受:*/*>< HTTP/1.1 404< 内容类型: text/plain;charset=UTF-8< 内容长度:26< 日期:格林威治标准时间 2018 年 8 月 9 日星期四 18:00:56<* 连接 #0 到主机 localhost 保持不变找不到员工 99
此消息很好地显示了HTTP 404错误以及自定义消息Could not find employee 99。
显示当前编码的交互并不难……
如果您使用 Windows 命令提示符发出 cURL 命令,则以下命令可能无法正常工作。您必须选择一个支持单引号参数的终端,或者使用双引号,然后转义 JSON 中的那些。
要创建新Employee记录,我们在终端中使用以下命令——$开头的表示后面是终端命令:
$ curl -X POST localhost:8080/employees -H 'Content-type:application/json' -d '{"name": "Samwise Gamgee", "role": "gardener"}'
然后它存储新创建的员工并将其发送回给我们:
{"id":3,"name":"Samwise Gamgee","role":"gardener"}
您可以更新用户。让我们改变他的角色。
$ curl -X PUT localhost:8080/employees/3 -H 'Content-type:application/json' -d '{"name": "Samwise Gamgee", "role": "ring bearer"}'
我们可以看到输出中反映的变化。
{"id":3,"name":"Samwise Gamgee","role":"戒指持有者"}
您构建服务的方式可能会产生重大影响。在这种情况下,我们说update,但replace是更好的描述。例如,如果未提供名称,则它将被取消。
最后,您可以像这样删除用户:
$ curl -X DELETE 本地主机:8080/employees/3# 现在如果我们再看一遍,它就不见了$ curl localhost:8080/employees/3找不到员工 3
这一切都很好,但是我们有 RESTful 服务了吗?(如果你没有听懂提示,答案是否定的。)
少了什么东西?
......未完待续......
2022就业季|Spring认证教你,如何使用 Spring 构建 REST 服务
#java##spring##spring认证##2022就业季#
以上就是今天关于Spring的一些讨论,对你有帮助吗?如果你有兴趣深入了解,欢迎到Spring中国教育管理中心留言交流!
审核编辑:汤梓红
