使用AXI performance monitors(APM)测试MPSoC DDR访问带宽
MPSoC的DDR控制器的数据通道上集成了 AXI performance monitors (APM)。具体情况,可以参考Xilinx UG1085 (v2.2)中Chapter 15的“Figure 15‐1: PS Interconnect”或者Figure 17-1。
1. APM驱动程序
对于AXI performance monitors (APM),xilinx提供的驱动程序是drivers\uio\uio_xilinx_apm.c,相关匹配字符串和主要数据结构如下:
static const struct of_device_id xapm_of_match[] = {
        { .compatible = "xlnx,axi-perf-monitor", },
        { /* end of table*/ }
MODULE_DEVICE_TABLE(of, xapm_of_match);
static struct platform_driver xapm_driver = {
        .driver = {
                 .name = "xilinx-axipmon",
                 .of_match_table = xapm_of_match,
                 .pm = &xapm_dev_pm_ops,
        .probe = xapm_probe,
        .remove = xapm_remove,
APM驱动程序最终会注册UIO设备。
在每个单板的device tree里,会支持DDR的APM。比如,在VCU TRD里,为DDR的APM定义了下面字段。
 perf-monitor@fd0b0000 {
                    compatible = "xlnx,axi-perf-monitor";
                    reg = <0x00 0xfd0b0000 0x00 0x10000> ;
                    interrupts = <0x00 0x7b 0x04> ;
                    interrupt-parent = <0x04> ;
                    xlnx,enable-profile = <0x00> ;
                    xlnx,enable-trace = <0x00> ;
                    xlnx,num-monitor-slots = <0x06> ;
                    xlnx,enable-event-count = <0x01> ;
                    xlnx,enable-event-log = <0x00> ;
                    xlnx,have-sampled-metric-cnt = <0x01> ;
                    xlnx,num-of-counters = <0x0a> ;
                    xlnx,metric-count-width = <0x20> ;
                    xlnx,metrics-sample-count-width = <0x20> ;
                    xlnx,global-count-width = <0x20> ;
                    xlnx,metric-count-scale = <0x01> ;
                    clocks = <0x03 0x1c> ;
                    phandle = <0x9b> ;
     perf_monitor_ddr = "/amba/perf-monitor@fd0b0000";
OCM、CCI等模块也有APM。
perf_monitor_ocm = "/amba/perf-monitor@ffa00000";
     perf_monitor_cci = "/amba/perf-monitor@fd490000";
     perf_monitor_lpd = "/amba/perf-monitor@ffa10000";
单板Linux启动后,能查询到对应的UIO设备。
root@vcu_trd:~# ls /dev/uio*
/dev/uio0  /dev/uio1  /dev/uio2  /dev/uio3  /dev/uio4
2. APM用户态程序
对于AXI performance monitors (APM),xilinx也提供了用户态程序,是apm_main.elf。使用apm_main.elf,可以查询APM监视到的DDR带宽利用情况。
root@vcu_trd:~# chmod +x apm_main.elf
root@vcu_trd:~# ./apm_main.elf -d /dev/uio0
AXI PMON is in Advanced Mode
port 1 read: 0 0.00 MBps
port 1 write: 0 0.00 MBps
port 2 read: 0 0.00 MBps
port 2 write: 0 0.00 MBps
port 4 read: 0 0.00 MBps
port 4 write: 0 0.00 MBps
port 5 read: 0 0.00 MBps
port 5 write: 0 0.00 MBps
root@vcu_trd:~#
root@vcu_trd:~# ./apm_main.elf -d /dev/uio1
port 1 read: 12523440 12.52 MBps
port 1 write: 7564856 7.56 MBps
port 2 read: 13290992 13.29 MBps
port 2 write: 7493209 7.49 MBps
port 4 write: 331253760 331.25 MBps
port 5 read: 667254864 667.25 MBps
port 5 write: 320656878 320.66 MBps
root@vcu_trd:~# ./apm_main.elf -d /dev/uio2
root@vcu_trd:~# ./apm_main.elf -d /dev/uio3
上述设备“/dev/uio1”代表DDR APM1。在使用VCU TRD进行1080p编码时,port 4写带宽331.25 MBps,port 5读带宽667.25 MBps,port 5写带宽320.66 MBps。每个DDR port对应的硬件模块,请参考ug1085的Figure 17-1。port 4连接到了HP 1/HP 2。port 5连接到了HP 3。
APM
  审核编辑:汤梓红
