Camera驱动分析
Linux版本:4.19
Sensor: OV13850
(1)装载和卸载函数
//DTS匹配表
static const struct of_device_id ov13850_of_match[] = {
{.compatible = "omnivision,ov13850-v4l2-i2c-subdev"},
MODULE_DEVICE_TABLE(i2c, ov13850_id);
static struct i2c_driver ov13850_i2c_driver = {
.driver = {
.name = ov13850_DRIVER_NAME,
.owner = THIS_MODULE,
.of_match_table = ov13850_of_match
.probe = ov13850_probe,
.remove = ov13850_remove,
.id_table = ov13850_id,
module_i2c_driver(ov13850_i2c_driver);
OV13850是使用I2C接口进行控制,所以使用i2c_driver进行注册。
(2)probe()
static int ov13850_probe(struct i2c_client *client,
const struct i2c_device_id *id)
dev_info(&client->dev, "probing...\n");
ov13850_filltimings(&ov13850_custom_config); //填充时序信息
v4l2_i2c_subdev_init(&ov13850.sd, client, &ov13850_camera_module_ops); //初始化v4l2_subdev
ov13850.sd.flags |= V4L2_SUBDEV_FL_HAS_DEVNODE;
ov13850.custom = ov13850_custom_config;
mutex_init(&ov13850.lock);
dev_info(&client->dev, "probing successful\n");
return 0;
上面主要是根据全局变量ov13850_custom_config中的信息填充时序信息。然后初始化v4l2_subdev, ov13850是I2C接口,所以使用v4l2_i2c_subdev_init 进行初始化。v4l2_i2c_subdev_init就是对v4l2_subdev_init的封装。
//v4l2_subdev_ops
static struct v4l2_subdev_ops ov13850_camera_module_ops = {
.core = &ov13850_camera_module_core_ops, //核心操作
.video = &ov13850_camera_module_video_ops, //video操作
.pad = &ov13850_camera_module_pad_ops
static struct ov_camera_module_custom_config ov13850_custom_config = {
.start_streaming = ov13850_start_streaming, //sensor开始输出数据流
.stop_streaming = ov13850_stop_streaming, //sensor停止输出数据流
.s_ctrl = ov13850_s_ctrl,
.s_ext_ctrls = ov13850_s_ext_ctrls, //sensor控制(设置自动曝光控制)
.g_ctrl = ov13850_g_ctrl,
.g_timings = ov13850_g_timings, //获取sensor时序
.check_camera_id = ov13850_check_camera_id, //读取Sensor ID
.s_vts = ov13850_auto_adjust_fps, //自动调节刷新率
.set_flip = ov13850_set_flip, //设置sensor镜像
#ifdef OV13850_ONE_LANE
.configs = ov13850_onelane_configs, //单lane的配置信息(分辨率,刷新率等)
.num_configs = ARRAY_SIZE(ov13850_onelane_configs),
#else
.configs = ov13850_configs, //多lane的配置信息
.num_configs = ARRAY_SIZE(ov13850_configs),
#endif
.power_up_delays_ms = {5, 20, 0},
*0: Exposure time valid fileds; 曝光时间
*1: Exposure gain valid fileds; 曝光增益
*(2 fileds == 1 frames)
.exposure_valid_frame = {4, 4}
上面设置的回调基本都是去设置寄存器。
(3)打开数据流
static int ov13850_start_streaming(struct ov_camera_module *cam_mod)
int ret = 0;
ov_camera_module_pr_debug(cam_mod,
"active config=%s\n", cam_mod->active_config->name);
ret = ov13850_g_VTS(cam_mod, &cam_mod->vts_min);
if (IS_ERR_VALUE(ret))
goto err;
mutex_lock(&cam_mod->lock);
ret = ov_camera_module_write_reg(cam_mod, 0x0100, 1); //写0x0100寄存器, 选择streaming模式 0:standby 1:streaming
mutex_unlock(&cam_mod->lock);
goto err;
msleep(25);
return 0;
err:
ov_camera_module_pr_err(cam_mod, "failed with error (%d)\n",
ret);
return ret;
主要就是操作寄存器,开启数据流传输。其他的一些操作函数也基本类似。
总结
我们从上面的内容中可以看出,sensor端的驱动没有特别复杂,主要是一些参数和控制相关的内容。sensor主要是生产数据,而数据的处理主要交给ISP。
审核编辑:刘清
