兼容Vicor VI200以及VE200系列的EBB系列砖块电源
电源/新能源
3654人已加入
可以兼容Vicor VI200以及VE200系列的砖块电源
---EBB系列
EBB系列电源特点:
兼容Vicor VI200及VE200系列
陶瓷基板PCB
丝印电阻
效率高达94.5%
工作温度范围:-40℃~+85℃
EMC/EMV符合EN55022-B
防火等级:UL94-V0
• SMT - on ceramic technology
• Full Brick - metal case
• 100% burn-in & parameter test
• Assembling according to ANSI/IPC-A-610
• Laser trimmed thick film resistors
• High efficiency up to 94,5%
• Short circuit proof
• Extended temperature range: -40°C to +85°C
• EMC/EMV compliant according EN55022-B
• Integrated pi Input filter
• RoHS compliant
• UL94V-0 compliant
Examples of Part Number
Model Input Output Efficiency Optional
EBB100-24-12-O 18V to 36V 12V /
8,33A
93% with On/Off pin
EBB100-24-18-S 18V to 36V 18V /
5,56A
92,5% with Sense pin
EBB100-36-48 21V to 51V 48V /
2,09A
90,5% no additional pin
EBB100-36-24-S 21V to 51V 24V /
4,17A
92% with Sense pin
EBB100-48-48 36V to 76V 48V /
2,09A
91,5% no additional pin
EBB100-48-12-T 36V to 76V 12V /
8,33A
93,5% On/Off and
sense pin
EBB100-72-15-S 55V to 100V 15V /
6,67A
94% with Sense pin
EBB100-72-36 55V to 100V 36V /
 2,78A
93% no additional pin
EBB100-110-12-S 66V to 154V 12V /
8,33A
94% with Sense pin
EBB100-110-48-O 66V to 154V 48V /
2,09A
92% with On /Off pin
EBB100-150-15 100V to 375V 15V /
6,67A
93,5% no additional pin
EBB100-150-36-O 100V to 375V 36V /
2,78A
91% with On/Off pin
Part Numbering Syetem
EBB 100 36 24 T
Seire Power Input Output Optional
EBB 100:100W 24: 18V to 36V 12: 12V O: With On / Off
pin (no sense pin)
36: 21V to 51V 15: 15V S: With Sense Pin (no On / off pin)
48: 36V to 76V 18: 18V T: With On / Off
and Sense Pin
72V: 55V to
100V
24: 24V -
110: 66V to
154V
36: 36V -
150V: 100V to 375V 48: 48V -
- XX:
custom
 solution
- value
 between
- 12 and 48 -
General electrical specifications (Note1)
Input Nominal input
voltage
24V
DC
36V
DC
48V
DC
72V
DC
110V DC 150V DC
Input
voltage
range
18 -
 36V
21 -
51V
36 -
76V
55 -
100V
66 -
154V
100 – 375V
Low side turn
off / on
16V / 17,5V 18V / 20V 33V / 35V 52V / 54V 58V / 64V 95V / 99V
High side turn
off / on
39 /
37V
54V / 53V 79V / 77V 106V / 103V 165V / 160V 382V / 378V
Max.
input
voltage
50V
DC
100V DC 100V DC 150V DC 200V DC 400V DC
No load input
current
< 25 mA < 25 mA < 15 mA < 15 mA < 15 mA < 15 mA
Nominal input
current
4,46 A 2,97 A 2,23 A 1,49 A 0,97 A 0,71 A
Efficiency up to
 93%
up to
93,5%
up to
93,5%
up to
94%
up to
94%
up to
93,5%
output Output
voltage
12V 15V 18V 24V 36V 48V
Output
current
8,33A 6,67A 5,56A 4,17A 2,78A 2,09A
Output voltage accuracy ± 1%
Regulation
line³
(Note 2)
± 1%
Regulation
 load
(Note 3)
± 2%
Ripple
 (20 MHz)
< 100 mVpp < 150 mVpp < 300 mVpp
Protection Short circuit protection current limiting
Overload protection Thermal shutdown @ ca 120°C
Isolation Isolation I/O 3000Vrms
Isolation I/ case 1500Vrms
Isolation O/case 1000Vrms
Environment Operating temperature -40 to +85°C
(Note 4) Storage temperature -55 to +125°C
Other Temperature coefficient 0,02%/°C
Notes:
1. Typical specifications at Ta = 25°C under normal line voltage and full load conditions, unless otherwise noted; external input
and output capacitor required
2. Ui min to Ui max
3. Imin = 0 to Imax = 100%
4. Case temperature
Mechanic solution
smt
Output power vs. case temperature
smt
审核编辑:刘清
