笔者在日常项目中经常需要使用C语言求一个文件的大小,特整理了一些常用的方法,通过测试代码的形式展示出来,话不多说,直接上代码:
#include
#include
#include
#include
#include
#include
#include
#define TEST_FILE "./IMG_3458.JPG"
// call stat() function
static int get_file_size_by_stat(const char *file)
int ret;
struct stat file_info;
printf("enter %s() >>>\n", __func__);
ret = stat(file, &file_info);
return (!ret) ? file_info.st_size : -1;
// call lstat() function
static int get_file_size_by_lstat(const char *file)
int ret;
ret = lstat(file, &file_info);
// call fstat() function
static int get_file_size_by_fstat(const char *file)
int ret;
int fd;
fd = open(file, O_RDONLY);
if (fd < 0) {
ret = -1;
perror("open error");
goto exit_entry;
ret = fstat(fd, &file_info);
exit_entry:
if (fd >= 0) {
close(fd);
// call lseek() function
static int get_file_size_by_lseek(const char *file)
int ret;
int fd;
if (fd < 0) {
ret = -1;
goto exit_entry;
ret = lseek(fd, 0, SEEK_END);
exit_entry:
if (fd >= 0) {
close(fd);
return ret;
// call fseek() and ftell() function
static int get_file_size_by_fseek_and_ftell(const char *file)
int ret;
FILE *fp;
fp = fopen(file, "r");
if (!fp) {
ret = -1;
perror("fopen error");
goto exit_entry;
ret = fseek(fp, 0, SEEK_END);
if (ret < 0) {
ret = -1;
perror("fseek error");
goto exit_entry;
ret = ftell(fp);
exit_entry:
if (fp) {
fclose(fp);
return ret;
static int shell_cmd_excute(const char *cmd, char *result, int size)
int ret;
FILE *fp;
fp = popen(cmd, "r");
if (!fp) {
ret = -1;
perror("popen error");
goto exit_entry;
ret = fread(result, 1, size, fp);
if (ret < 0) {
ret = -1;
goto exit_entry;
ret = 0;
exit_entry:
if (fp) {
pclose(fp);
return ret;
// call shell cmd
static int get_file_size_by_shell_cmd(const char *file)
int ret;
char cmd[128];
char result[16];
snprintf(cmd, sizeof(cmd), "ls -al %s | awk '{print $5}'", file);
printf("shell cmd: %s\n", cmd);
ret = shell_cmd_excute(cmd, result, sizeof(result));
if (!ret && strlen(result)) {
ret = atoi(result);
return ret;
int main(int argc, const char *argv[])
int file_size;
file_size = get_file_size_by_stat(TEST_FILE);
printf("file_size=%d\n\n\n", file_size);
file_size = get_file_size_by_lstat(TEST_FILE);
file_size = get_file_size_by_fstat(TEST_FILE);
file_size = get_file_size_by_lseek(TEST_FILE);
file_size = get_file_size_by_fseek_and_ftell(TEST_FILE);
file_size = get_file_size_by_shell_cmd(TEST_FILE);
return 0;
测试记录如下:
被测试文件,在windows下查看大小为:
如上测试代码,编译出来,运行结果如下所示,测试证明,所有的获取方法均是有效的。
好了,本次使用C语言获取文件大小的方法就介绍到这里,如果你有更加方便、快捷、高效的方法,也可以在评论席告知,感激不尽。
