https://docs.redis.com/latest/ri/RedisInsight 提供的功能:
唯一支持 Redis Cluster 的 GUI 工具;
可以基于 Browser 的界面来进行搜索键、查看和编辑数据;
支持基于 SSL/TLS 的连接,同时还可以在界面上进行内存分析;
二、RedisInsight 安装与使用https://redis.com/redis-enterprise/redis-insight/#insight-form
[root@Redis ~]# ls anaconda-ks.cfg redisinsight-linux64-1.11.0 [root@Redis ~]# mkdir /usr/local/redisinsight [root@Redis ~]# mv redisinsight-linux64-1.11.0 /usr/local/redisinsight/redisinsight-1.11.0 [root@Redis ~]# chmod +x /usr/local/redisinsight/redisinsight-1.11.0
配置 RedisInsight 的环境变量[root@Redis ~]# echo "export REDISINSIGHT_HOST=192.168.1.1" >> ~/.bash_profile [root@Redis ~]# echo "export REDISINSIGHT_HOST_DIR=/usr/local/redisinsight/.redisinsight" >> ~/.bash_profile [root@Redis ~]# source ~/.bash_profile 注解:
REDISINSIGHT_PORT:配置 RedisInsight 的监听端口(default:8001)
REDISINSIGHT_HOST:配置 RedisInsight 的 IP 地址(default:0.0.0.0)
LOG_DIR:配置 RedisInsight 的日志存放路径(default:REDISINSIGHT_HOST_DIR)
REDISINSIGHT_HOST_DIR:配置 RedisInsight 的数据存放路径(default:~/.redisinsight)启动 RedisInsight 服务[root@Redis ~]# nohup /usr/local/redisinsight/redisinsight-linux64-1.4.0 & // 后台运行 [root@Redis ~]# ps aux | grep redis // 查看进程是否存在
[root@Redis ~]# vim redisinsight.yaml apiVersion: v1 kind: Service metadata: name: redisinsight-service spec: type: NodePort ports: - port: 80 targetPort: 8001 nodePort: 31888 selector: app: redisinsight --- apiVersion: apps/v1 kind: Deployment metadata: name: redisinsight labels: app: redisinsight spec: replicas: 1 selector: matachLabels: app: redisinsight template: metadata: labels: app: redisinsight spec: containers: - name: redisinsight image: redislabs/redisinsight:1.7.0 imagePullPolicy: IfNotPresent volumeMounts: - name: db mountPath: /db ports: - containerPort: 8001 protocol: TCP volumes: - name: db emptyDir: {} 2)启动 RedisInsight
[root@Redis ~]# kubectl apply -f redisinsight.yaml
[root@Redis ~]# wget https://download.redis.io/releases/redis-6.2.6.tar.gz [root@Redis ~]# tar zxf redis-6.2.6.tar.gz [root@Redis ~]# cd redis-6.2.6 [root@Redis redis-6.2.6]# make PREFIX=/usr/local/redis install [root@Redis redis-6.2.6]# sed -i '/^bind 127.0.0.1/s/127.0.0.1/192.168.1.1/g' redis.conf # 修改监听 IP [root@Redis redis-6.2.6]# sed -i '/protected-mode/s/yes/no/g' redis.conf # 关闭保护模式 [root@Redis redis-6.2.6]# sed -i '/daemonize/s/no/yes/g' redis.conf # 开启后台运行 [root@Redis redis-6.2.6]# sed -i '/requirepass/s/foobared/123123/g' redis.conf # 配置密码 [root@Redis redis-6.2.6]# sed -i '/requirepass 123123/s/^#//g' redis.conf # 将密码前的 # 删除 [root@Redis redis-6.2.6]# cp redis.conf /usr/local/redis/ [root@Redis redis-6.2.6]# /usr/local/redis/bin/redis-server /usr/local/redis/redis.conf # 启动 Redis
在这里可以看到 Redis 的各种信息:
同时 RedisInsight 还可以在界面上进行操作:
还可以在界面上对 Redis 使用的内存进行分析:
-End-
审核编辑 :李倩
