CMSIS_V1和CMSIS_V2有什么区别呢,该怎选择呢?
STM32CubeIDE在stm32开发者起着最基础的作用,在STM32CubeIDE中配置FreeRTOS中间层时需要选择interface,其中有三个选项:Disable、CMSIS_V1和CMSIS_V2
CMSIS定义了通用工具接口,并提供一致的设备支持,那么CMSIS_V1和CMSIS_V2有什么区别呢,该怎选择呢?
CMSIS
微控制器软件接口标准CMSIS
CMSIS ARM官方定义如下:
CMSIS
Cortex微控制器软件接口标准(CMSIS)是独立于供应商的硬件抽象层,用于基于Arm Cortex处理器的微控制器,并且CMSIS提供了到处理器和外围设备,实时操作系统以及中间件组件的接口,可以说非常实用。
CMSIS软件接口简化了软件重用,减少了开发周期,而且也不受限操作系统的类型,去耦。
不同之处
  • RTOS v1使得软件能够在不同的实时操作系统下运行(屏蔽不同RTOS提供的API的差别)
  • 而RTOS v2则是拓展了RTOS v1,兼容更多的CPU架构和实时操作系统。
RTOS v1创建任务函数如下:
/*********************** Thread Management *****************************/
* @brief  Create a thread and add it to Active Threads and set it to state READY.
* @param  thread_def    thread definition referenced with
ef osThread.
* @param  argument      pointer that is passed to the thread function as start argument.
* @retval thread ID for reference by other functions or NULL in case of error.
* @note   MUST REMAIN UNCHANGED:  osThreadCreate shall be consistent in every CMSIS-RTOS.
osThreadId osThreadCreate (const osThreadDef_t *thread_def, void *argument)
  TaskHandle_t handle;
#if( configSUPPORT_STATIC_ALLOCATION == 1 ) &&  ( configSUPPORT_DYNAMIC_ALLOCATION == 1 )
  if((thread_def->buffer != NULL) && (thread_def->controlblock != NULL)) {
    handle = xTaskCreateStatic((TaskFunction_t)thread_def->pthread,(const portCHAR *)thread_def->name,
              thread_def->stacksize, argument, makeFreeRtosPriority(thread_def->tpriority),
              thread_def->buffer, thread_def->controlblock);
  else {
    if (xTaskCreate((TaskFunction_t)thread_def->pthread,(const portCHAR *)thread_def->name,
              &handle) != pdPASS)  {
      return NULL;
#elif( configSUPPORT_STATIC_ALLOCATION == 1 )
#else
    return NULL;
#endif
  return handle;
RTOS v2创建任务函数如下:
osThreadId_t osThreadNew (osThreadFunc_t func, void *argument, const osThreadAttr_t *attr) {
  const char *name;
  uint32_t stack;
  TaskHandle_t hTask;
  UBaseType_t prio;
  int32_t mem;
  hTask = NULL;
  if (!IS_IRQ() && (func != NULL)) {
    stack = configMINIMAL_STACK_SIZE;
    prio  = (UBaseType_t)osPriorityNormal;
    name = NULL;
    mem  = -1;
    if (attr != NULL) {
      if (attr->name != NULL) {
        name = attr->name;
      if (attr->priority != osPriorityNone) {
        prio = (UBaseType_t)attr->priority;
      if ((prio < osPriorityIdle) || (prio > osPriorityISR) || ((attr->attr_bits & osThreadJoinable) == osThreadJoinable)) {
        return (NULL);
      if (attr->stack_size > 0U) {
        /* In FreeRTOS stack is not in bytes, but in sizeof(StackType_t) which is 4 on ARM ports.       */
        /* Stack size should be therefore 4 byte aligned in order to avoid division caused side effects */
        stack = attr->stack_size / sizeof(StackType_t);
      if ((attr->cb_mem    != NULL) && (attr->cb_size    >= sizeof(StaticTask_t)) &&
          (attr->stack_mem != NULL) && (attr->stack_size >  0U)) {
        mem = 1;
      else {
        if ((attr->cb_mem == NULL) && (attr->cb_size == 0U) && (attr->stack_mem == NULL)) {
          mem = 0;
    else {
      mem = 0;
    if (mem == 1) {
      #if (configSUPPORT_STATIC_ALLOCATION == 1)
        hTask = xTaskCreateStatic ((TaskFunction_t)func, name, stack, argument, prio, (StackType_t  *)attr->stack_mem,
        (StaticTask_t *)attr->cb_mem);
      #endif
    else {
      if (mem == 0) {
        #if (configSUPPORT_DYNAMIC_ALLOCATION == 1)
          if (xTaskCreate ((TaskFunction_t)func, name, (uint16_t)stack, argument, prio, &hTask) != pdPASS) {
            hTask = NULL;
        #endif
  return ((osThreadId_t)hTask);
正常V1够用了,普通功能选V1,高级功能选择V2:
我分别选择CMSIS_V1和CMSIS_V2编译了两次进行对比,CMSIS_V2都要大一些。
审核编辑 :李倩
