【安全算法之base64】base64加解密的C语言源码实现
​ 最近,有项目中需要用到base64的加解密,所以用C语言实现了一遍,测试效果还不错,代码量和RAM消耗都比较低,可以提供给大家参考下。
#include
#include
#include "base64.h"
static uint8_t get_index_from_char(char c)
    if ((c >= 'A') && (c <= 'Z'))           return (c - 'A');
    else if ((c >= 'a') && (c <= 'z'))      return (c - 'a' + 26);
    else if ((c >= '0') && (c <= '9'))      return (c - '0' + 52);
    else if (c == '+')                      return 62;
    else if (c == '/')                      return 63;
    else if (c == '=')                      return 64;
    else if ((c == 'r') || (c == 'n'))    return 254;
    else                                    return 255;
static char get_char_from_index(uint8_t i)
    if ((i >= 0) && (i <= 25))              return (i + 'A');
    else if ((i >= 26) && (i <= 51))        return (i - 26 + 'a');
    else if ((i >= 52) && (i <= 61))        return (i - 52 + '0');
    else if (i == 62)                       return '+';
    else if (i == 63)                       return '/';
    else                                    return '=';
int base64_encode(const uint8_t *in, uint16_t in_len, char *out)
    int i;
    uint32_t tmp = 0;
    uint16_t out_len = 0;
    uint16_t left = in_len;
    if ((!in) || (!out)) {
        //invalid parameter
        return BASE64_ERROR;
    for (i = 0; i < in_len;) {
        if (left >= 3) {
            tmp = in[i];
            tmp = (tmp << 8) + in[i+1];
            tmp = (tmp << 8) + in[i+2];
            out[out_len++] = get_char_from_index((tmp & 0x00FC0000) >> 18);
            out[out_len++] = get_char_from_index((tmp & 0x0003F000) >> 12);
            out[out_len++] = get_char_from_index((tmp & 0x00000FC0) >> 6);
            out[out_len++] = get_char_from_index(tmp & 0x0000003F);
            left -= 3;
            i += 3;
        } else {
            break;
    if (left == 2) {
        tmp = in[i];
        out[out_len++] = get_char_from_index((tmp & 0x0000FC00) >> 10);
        out[out_len++] = get_char_from_index((tmp & 0x000003F0) >> 4);
        out[out_len++] = get_char_from_index((tmp & 0x0000000F) << 2);
        out[out_len++] = get_char_from_index(64);
    } else if (left == 1) {
        tmp = in[i];
        out[out_len++] = get_char_from_index((tmp & 0x000000FC) >> 2);
        out[out_len++] = get_char_from_index((tmp & 0x00000003) << 4);
    out[out_len] = '';
    return BASE64_SUCCESS;
int base64_decode(const char *in, uint8_t *out, uint16_t *out_len)
    uint16_t i = 0, cnt = 0;
    uint8_t c, in_data_cnt;
    bool error_msg = false;
    uint32_t tmp = 0;
    if ((!in) || (!out) || (!out_len)) {
        //invalid parameter
    in_data_cnt = 0;
    while (in[i] != '') {
        c = get_index_from_char(in[i++]);
        if (c == 255) {
            //MSG_PRINTF(LOG_ERR, "INVALID MESSAGE CODEn");
            return BASE64_ERR_BASE64_BAD_MSG;
        } else if (c == 254) {
            continue;           // Carriage return or newline feed, skip
        } else if (c == 64) {
            break;              // Meet '=', break
        tmp = (tmp << 6) | c;
        if (++in_data_cnt == 4) {
            out[cnt++] = (uint8_t)((tmp >> 16) & 0xFF);
            out[cnt++] = (uint8_t)((tmp >> 8) & 0xFF);
            out[cnt++] = (uint8_t)(tmp & 0xFF);
            in_data_cnt = 0;
            tmp = 0;
    // Meet '=' or ''
    if (in_data_cnt == 3) {          // 3 chars before '=', encoded msg like xxx= OR
        tmp = (tmp << 6);           // 3 chars before '', encoded msg like xxx, considered '=' omitted
    } else if (in_data_cnt == 2) {   // 2 chars before '=', encoded msg like xx== OR
        tmp = (tmp << 6);           // 2 chars before '', encoded msg like xx, considered '=' omitted
        tmp = (tmp << 6);
    } else if (in_data_cnt != 0) {
        error_msg = true;           // Warn that the message format is wrong, but we tried our best to decode
    *out_len = cnt;
    return (error_msg ? BASE64_ERROR : BASE64_SUCCESS);
RAM
简单写了一个测试demo,有兴趣的可以一起看下。
#include
#include
#include "base64.h"
#include "convert.h"
int log_hexdump(const char *title, const unsigned char *data, int len)
    char str[160], octet[10];
    int ofs, i, k, d;
    const unsigned char *buf = (const unsigned char *)data;
    const char dimm[] = "+------------------------------------------------------------------------------+";
    printf("%s (%d bytes):rn", title, len);
    printf("%srn", dimm);
    printf("| Offset  : 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F   0123456789ABCDEF |rn");
    for (ofs = 0; ofs < (int)len; ofs += 16) {
        d = snprintf( str, sizeof(str), "| %08X: ", ofs );
        for (i = 0; i < 16; i++) {
            if ((i + ofs) < (int)len) {
                snprintf( octet, sizeof(octet), "%02X ", buf[ofs + i] );
            } else {
                snprintf( octet, sizeof(octet), "   " );
            d += snprintf( &str[d], sizeof(str) - d, "%s", octet );
        d += snprintf( &str[d], sizeof(str) - d, "  " );
        k = d;
                str[k++] = (0x20 <= (buf[ofs + i]) &&  (buf[ofs + i]) <= 0x7E) ? buf[ofs + i] : '.';
            } else {
                str[k++] = ' ';
        str[k] = '';
        printf("%s |rn", str);
    return 0;
int main(int argc, const char *argv[])
	const char *data = "C1D0F8FB4958670DBA40AB1F3752EF0D";
	char base64_enc_calc[128] = {0};
	char base64_enc_exp[128] = "QzFEMEY4RkI0OTU4NjcwREJBNDBBQjFGMzc1MkVGMEQ=";
	const char *p_calc = data;
    uint8_t base64_dec_calc[128];
    uint16_t base64_dec_len = 0;
    int ret;
	if (argc > 1) {
		p_calc = argv[1];
    ret = base64_encode((const uint8_t *)p_calc, strlen(p_calc), base64_enc_calc);
	if (!ret && !strcmp(base64_enc_calc, base64_enc_exp)) {
        printf("base64_enc_calc: %sn", base64_enc_calc);
		printf("BASE64 encryption test OKn");
	} else {
        printf("base64_enc_exp : %sn", base64_enc_exp);
		printf("BASE64 encryption test FAILn");
    ret = base64_decode(base64_enc_calc, base64_dec_calc, &base64_dec_len);
    printf("ret: %dn", ret);
    if (!ret && !strcmp((char *)base64_dec_calc, p_calc)) {
        printf("base64_dec_calc: %sn", base64_dec_calc);
        printf("BASE64 decryption test OKn");
    } else {
        printf("base64_org_data: %sn", p_calc);
        printf("BASE64 decryption test FAILn");
	return 0;
RAM
测试结果,还挺正常的。
recan@ubuntu:~/win_share_workspace/coding-01workstation/workspace/crypto/base64$
recan@ubuntu:~/win_share_workspace/coding-01workstation/workspace/crypto/base64$ ./build.sh
gcc base64.c test.c ../../utils/convert.c -I../../utils -Wall -Werror -o test
recan@ubuntu:~/win_share_workspace/coding-01workstation/workspace/crypto/base64$ ./test
base64_enc_calc: QzFEMEY4RkI0OTU4NjcwREJBNDBBQjFGMzc1MkVGMEQ=
ret: 0
base64_dec_calc: C1D0F8FB4958670DBA40AB1F3752EF0D
审核编辑:刘清
评论(0)
发评论
yuchl 2022-10-09
0 回复 举报
不错!! 收起回复
= 'A') && (c = 'a') && (c = '0') && ">
