Dolphin 大功率评估套件
模拟技术
2518人已加入
  产品说明
  Dolphin is a Frequency Hopping Spread Spectrum (FHSS) Wireless UART chipset for the 902-928 MHz US ISM Band. The Dolphin chipset consists of the TRF6903 RF transciever and the digital baseband ASIC DBB03A and comes FCC pre-certified.
  DOLPHIN-HP-EVM is the evaluation kit for the High Power Dolphin chipset. With this hardware the user is able to demonstrate, test, and evaluate two way point-to-point communication. The evaluation kit contains:
  Two High Power daughter cards
  Two Interface cards
  Two RS-232 Serial Cables to connect to a computer
  Graphical evaluation software
  All applicable literature and data sheet
  To demonstrate the broADCast capability of the Dolphin chipset, an additional adder kit is available. Please see DOLPHIN-LP-ADDER for a low power adder kit, or DOLPHIN-HP-ADDER for a high power adder kit.
  特性
  Hardware Features:
  Chipset Solution - TRF6903 RF Transceiver and DBB03 Digital Baseband ASIC (firmware in ROM-based program memory)
  FHSS FSK operation in the 902-928 MHz US ISM band
  Fastest frequency hopping solution available resulting in fast acquisition and less power consumption. (Channel lock time of 200µs; No calibration needed when frequency hopping)
  Evaluation software or system micro can be used to evaluate/program the Dolphin chipset using a defined host-interface protocol
  +23 dBm output Power
  2.7-3.6 V operation
  RF bit rate of 38.4 kbps
  50 hopping channels and multiple hop tables
  FCC pre-certified per testing at LS Compliance
  Transmisson Range of 1 mile
  -101 dBm sensitivity at 38.4 kbps bit rate
  Software Features:
  Simple, hardware UART interface for an external system microcontroller
  AcknowLEDgement/Retry for reliable data transfer
  Packet routing to increase communication range
  Supports Point-to-Point and Broadcast Networks
  Hierarchical Network definition: Each Transceiver has a Transceiver ID(unique), Network ID and System ID
  U
  p to 65536 Transceivers can be configured within a single System
  Network Partitioning: Only Transceivers with same System ID, Network ID and same hopset communicate
  Up to 16 distinct hopsets. Each hopset contains 50 frequencies. Transceivers with different hopsets will not communicate
  Modular Firmware Facilitates Easy Customization
  包含项目
  SWRA045,InteRFacing Dolphin to an External System Microcontroller
  SWRA043,Dolphin -- Frequency Hopping Spread Spectrum Chipset Host Interface Protocol
  SWRC007,Dolphin Evaluation Tool
  SLLU090,Dolphin Frequency Hopping Spread Spectrum Evaluation Kit Hardware & Software UG
