Fuzzing101实践之GIMP
6. Fuzzing101 - 6 GIMP
1. 目标环境配置
本次的目标程序是一个带有GUI的可交互的程序,在构建编译上会比之前的软件稍微有一丢丢复杂。
首先要安装gimp会使用到的 GEGL 0.2(Generic Graphics Library),尝试使用源码编译:
# install  dependenciessudo apt install build-essential libatk1.0-dev libfontconfig1-dev libcairo2-dev libgudev-1.0-0 libdbus-1-dev libdbus-glib-1-dev libexif-dev libxfixes-dev libgtk2.0-dev python2.7-dev libpango1.0-dev libglib2.0-dev zlib1g-dev intltool libbabl-dev# download and uncompresswget https://download.gimp.org/pub/gegl/0.2/gegl-0.2.0.tar.bz2tar xvf gegl-0.2.0.tar.bz2 && cd gegl-0.2.0# modify the source codesed -i 's/CODEC_CAP_TRUNCATED/AV_CODEC_CAP_TRUNCATED/g' ./operations/external/ff-load.csed -i 's/CODEC_FLAG_TRUNCATED/AV_CODEC_FLAG_TRUNCATED/g' ./operations/external/ff-load.c# build and install./configure --enable-debug --disable-glibtest  --without-vala --without-cairo --without-pango --without-pangocairo --without-gdk-pixbuf --without-lensfun --without-libjpeg --without-libpng --without-librsvg --without-openexr --without-sdl --without-libopenraw --without-jasper --without-graphviz --without-lua --without-libavformat --without-libv4l --without-libspiro --without-exiv2 --without-umfpackmake -j$(nproc)sudo make install
这里对于 GEGL 这个图形库的编译安装我们不做过多介绍,这不是我们的重点,可以明确告知的是上面的库在编译时大概率会编译报错,导致一些库文件编译失败。所以,对于Ubuntu 20.04以上版本(我使用的是22.04)可以直接 sudo apt install libgegl-0.4-0 来安装这个0.4版本的库。(尽量不在非fuzz阶段浪费时间)
然后,下载 GIMP 2.8.16,并进行编译安装:
# download cd ..wget https://mirror.klaus-uwe.me/gimp/pub/gimp/v2.8/gimp-2.8.16.tar.bz2tar xvf gimp-2.8.16.tar.bz2 && cd gimp-2.8.16/# build and installCC=afl-clang-lto CXX=afl-clang-lto++ PKG_CONFIG_PATH=$PKG_CONFIG_PATH:/usr/local/lib/pkgconfig CFLAGS="-fsanitize=address" CXXFLAGS="-fsanitize=address" LDFLAGS="-fsanitize=address" ./configure --disable-gtktest --disable-glibtest --disable-alsatest --disable-nls --without-libtiff --without-libjpeg --without-bzip2 --without-gs --without-libpng --without-libmng --without-libexif --without-aa --without-libxpm --without-webkit --without-librsvg --without-print --without-poppler --without-cairo-pdf --without-gvfs --without-libcurl --without-wmf --without-libjasper --without-alsa --without-gudev --disable-python --enable-gimp-console --without-mac-twain --without-script-fu --without-gudev --without-dbus --disable-mp --without-linux-input --without-xvfb-run --with-gif-compression=none --without-xmc --with-shm=none --enable-debug  --prefix="$HOME/Desktop/Fuzz/training/fuzzing_gimp/gimp-2.8.16/install"AFL_USE_ASAN=1 make -j$(nproc)AFL_USE_ASAN=1 make install
这里的编译选项有点多,第一次的时候尽可能保持一致,避免出错,如果要进行优化和改进,可根据实际需求来增删编译选项。
编译完成后检查软件是否可以正常运行,命令行和图形界面都检查一下。
2. AFL++编译target
1. Persistent Mode
Persistent Mode 是 AFL 提供的一种可以加快fuzz 执行速度的功能,详细原理我们在源码解析的文章中已经进行了深入的介绍,这里大家只需要简单理解成无需每次都进行 fork 操作,而只是在程序的某一特定位置进行循环 fuzz。
2. 修改源码
我们需要在源码中找合适的位置插入 persistent mode 的执行代码,对于本例而言,有两处可以插入。第一处是 app.c 文件:
Target
第二处是 xcf.c 文件:
Target
至于为什么选择这两个地方进行 fuzz ,就看大家对软件流程和功能的理解程度了。
我们这里执行时,两种方案都测试一下。第二种方案,通过打补丁的方式来修改源码,补丁如下:
--- ../xcf.c    2014-08-20 08:27:58.000000000 -0700+++ ./app/xcf/xcf.c    2021-10-11 13:02:42.800831192 -0700@@ -277,6 +277,10 @@   filename = g_value_get_string (&args->values[1]);+#ifdef __AFL_COMPILER+  while(__AFL_LOOP(10000)){+#endif+   info.fp = g_fopen (filename, "rb");   if (info.fp)@@ -366,6 +370,12 @@   if (success)     gimp_value_set_image (&return_vals->values[1], image);+#ifdef __AFL_COMPILER+  }+#endif++  exit(0);+   gimp_unset_busy (gimp);   return return_vals;
需要注意的是,最后的 exit(0); 一定要有,否在程序会在 console 模式下卡住,导致 fuzz 的 test 都超时。
进行patch:
patch gimp-2.8.16/app/xcf/xcf.c -i persistent.patch
3. 执行fuzz
测试用例我们用一个最简单的:
mkdir afl_in && cd afl_inwget https://github.com/antonio-morales/Fuzzing101/blob/main/Exercise%206/SampleInput.xcf
这里还要注意,删除掉 gimp 的插件,这些插件可能会导致 gimp 运行失败:
rm ./install/lib/gimp/2.0/plug-ins/*
最后开启 fuzz:
ASAN_OPTIONS=detect_leaks=0,abort_on_error=1,symbolize=0 afl-fuzz -i './afl_in' -o './afl_out' -D -t 200 -M master -- ./gimp-2.8.16/install/bin/gimp-console-2.8 --verbose -d -f @@ASAN_OPTIONS=detect_leaks=0,abort_on_error=1,symbolize=0 afl-fuzz -i './afl_in' -o './afl_out' -D -t 200 -S slave1 -- ./gimp-2.8.16/install/bin/gimp-console-2.8 --verbose -d -f @@
审核编辑:汤梓红
