本文来源电子发烧友社区,作者:李先生, 帖子地址:https://bbs.elecfans.com/jishu_2308803_1_1.html
前言
嵌入式平台存储是影响综合性能的重要因素,所以本次对RAM和EMM性能进行测试,RAM压力测试也是一个重要的测试用例,尤其是在高低温等情况下测试,可以考察系统的稳定性。
过程RAM性能测试
WSL中
下载代码
cd STREAM/
编译
ARM-linux-gnueabihf-gcc -O3 stream.c -o stream
导出到windows下
cp stream /mnt/d
添加可执行权限
chmod +x stream
运行
./stream
结果如下
[root@EASY-EAI-NANO:/]# ./stream
STREAM version $Revision: 5.10 $
This system uses 8 bytes per array element.
Array size = 10000000 (elements), Offset = 0 (elements)
Memory per array = 76.3 MiB (= 0.1 GiB).
Total memory required = 228.9 MiB (= 0.2 GiB).
Each kernel will be executed 10 times.
The *best* time for each kernel (excluding the first iteration)
will be used to compute the reported bandwidth.
Your clock granularity/precision appears to be 1 microseconds.
Each test below will take on the order of 74402 microseconds.
(= 74402 clock ticks)
Increase the size of the arrays if this shows that
you are not getting at least 20 clock ticks per test.
WARNING -- The above is only a rough guideline.
For best results, please be sure you know the
precision of your system timer.
Function Best Rate MB/s Avg time Min time Max time
Copy: 2213.1 0.072951 0.072296 0.073413
Scale: 1526.0 0.105517 0.104846 0.108350
Add: 1181.8 0.203954 0.203082 0.205791
Triad: 954.5 0.253434 0.251431 0.255541
Solution Validates: avg error less than 1.000000e-13 on all three arrays
复制代码
参考https://www.cs.virginia.edu/stream/ref.html
RAM压力测试
参考 https://pyropus.ca./software/memtester/
WSL中
下载代码
tar -xvf memtester-4.5.1.tar.gz
cd memtester-4.5.1/
编译
arm-linux-gnueabihf-gcc -O3 memtester.c tests.c -o memtester
导出到WINDOWS下,下载到开发板
cp memtester /mnt/d
chmod +x memtester
运行
./memtester
运行结果如下,默认一直测试下去,可以最后指定测试次数
比如
./memtester 128M 1
128M
表示测试RAM大小
1表示测试一次
另外也可以-p直接指定物理地址,适合在板子开发阶段裸机代码直接指定物理地址测试。
[root@EASY-EAI-NANO:/]# ./memtester 128M 1
memtester version 4.5.1 (32-bit)
Copyright (C) 2001-2020 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
want 128MB (134217728 bytes)
got 128MB (134217728 bytes), trying mlock ...locked.
Loop 1/1:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Sequential Increment: ok
Solid Bits : ok
Block Sequential : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
Done.
复制代码
EMMC性能测试
dmesg | grep mmc
4GEMMC
[ 0.626234] mmc0: new HS200 MMC card at address 0001
[ 0.628264] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
EMMC速度为HS200
df查看,使用/userdata目录进行读写测试
[root@EASY-EAI-NANO:/]# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 1531442 593804 863917 41% /
devtmpfs 456488 0 456488 0% /dev
tmpfs 457000 0 457000 0% /dev/shm
tmpfs 457000 204 456796 0% /tmp
tmpfs 457000 380 456620 0% /run
/dev/mmcblk0p7 127955 1684 122289 1% /oem
/dev/mmcblk0p8 5632783 38040 5370524 1% /userdata
复制代码
bs/count 1GB
指令
结果
读
16k/65536
time dd if=/userdata/test.bin of=/dev/null bs=16k count=65536
109MB/S
4k/262144
1k/1048576
写
16k/65536
time dd if=/dev/zero of=/userdata/test.bin bs=16k count=65536
38MB/S
4k/262144
1k/1048576
[root@EASY-EAI-NANO:/]# time dd if=/dev/zero of=/userdata/test.bin bs=16k count=
65536
65536+0 records in
65536+0 records out
real 0m 26.85s
user 0m 0.08s
sys 0m 16.77s
[root@EASY-EAI-NANO:/]# time dd if=/userdata/test.bin of=/dev/null bs=16k count=
65536
65536+0 records in
65536+0 records out
real 0m 9.36s
user 0m 0.10s
sys 0m 4.54s
复制代码
以上仅作参考,实际欸有考虑缓存的影响。
SD卡性能测试
同EMMC测试,测试过程略。
SD卡自动挂载在/mnt/sdcard
总结
以上测试来看,性能是不错的,测试方法不是完全科学,比如EMMC读写没有考虑缓存,所以测试结果仅作参考。不同测试环境结果也可能不一样。
