几个必不可少的Linux运维脚本
嵌入式技术
1417人已加入
一、根据PID过滤进程所有信息
#! /bin/bash
# Function: 根据用户输入的PID,过滤出该PID所有的信息
read -p "请输入要查询的PID: " P
n=`ps -aux| awk '$2~/^'$P'$/{print $11}'|wc -l`
if [ $n -eq 0 ];then
 echo "该PID不存在!!"
 exit
fi
echo "--------------------------------"
echo "进程PID: $P"
echo "进程命令:`ps -aux| awk '$2~/^'$P'$/{print $11}'`"
echo "进程所属用户: `ps -aux| awk '$2~/^'$P'$/{print $1}'`"
echo "CPU占用率:`ps -aux| awk '$2~/^'$P'$/{print $3}'`%"
echo "内存占用率:`ps -aux| awk '$2~/^'$P'$/{print $4}'`%"
echo "进程开始运行的时刻:`ps -aux| awk '$2~/^'$P'$/{print $9}'`"
echo "进程运行的时间:`ps -aux| awk '$2~/^'$P'$/{print $10}'`"
echo "进程状态:`ps -aux| awk '$2~/^'$P'$/{print $8}'`"
echo "进程虚拟内存:`ps -aux| awk '$2~/^'$P'$/{print $5}'`"
echo "进程共享内存:`ps -aux| awk '$2~/^'$P'$/{print $6}'`"
PID
二、根据进程名过滤进程信息
会显示出该进程名包含的所有线程
#! /bin/bash
# Function: 根据输入的程序的名字过滤出所对应的PID,并显示出详细信息,如果有几个PID,则全部显示
read -p "请输入要查询的进程名:" NAME
N=`ps -aux | grep $NAME | grep -v grep | wc -l` ##统计进程总数
if [ $N -le 0 ];then
  echo "该进程名没有运行!"
fi
i=1
while [ $N -gt 0 ]
do
  echo "进程PID: `ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $2}'`"
  echo "进程命令:`ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $11}'`"
  echo "进程所属用户: `ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $1}'`"
  echo "CPU占用率:`ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $3}'`%"
  echo "内存占用率:`ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $4}'`%"
  echo "进程开始运行的时刻:`ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $9}'`"
  echo "进程运行的时间:` ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $11}'`"
  echo "进程状态:`ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $8}'`"
  echo "进程虚拟内存:`ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $5}'`"
  echo "进程共享内存:`ps -aux | grep $NAME | grep -v grep | awk 'NR=='$i'{print $0}'| awk '{print $6}'`"
  echo "***************************************************************"
  let N-- i++
done
PID
三、根据用户名查询该用户的相关信息
#! /bin/bash
# Function:根据用户名查询该用户的所有信息
read -p "请输入要查询的用户名:" A
echo "------------------------------"
n=`cat /etc/passwd | awk -F: '$1~/^'$A'$/{print}' | wc -l`
echo "该用户不存在"
else
  echo "该用户的用户名:$A"
  echo "该用户的UID:`cat /etc/passwd | awk -F: '$1~/^'$A'$/{print}'|awk -F: '{print $3}'`"
  echo "该用户的组为:`id $A | awk {'print $3'}`"
  echo "该用户的GID为:`cat /etc/passwd | awk -F: '$1~/^'$A'$/{print}'|awk -F: '{print $4}'`"
  echo "该用户的家目录为:`cat /etc/passwd | awk -F: '$1~/^'$A'$/{print}'|awk -F: '{print $6}'`"
  Login=`cat /etc/passwd | awk -F: '$1~/^'$A'$/{print}'|awk -F: '{print $7}'`
  if [ $Login == "/bin/bash" ];then
  echo "该用户有登录系统的权限!!"
  elif [ $Login == "/sbin/nologin" ];then
  echo "该用户没有登录系统的权限!!"
  fi
fi
PID
四、加固系统的一些配置
#! /bin/bash
# Function:对账户的密码的一些加固
read -p "设置密码最多可多少天不修改:" A
read -p "设置密码修改之间最小的天数:" B
read -p "设置密码最短的长度:" C
read -p "设置密码失效前多少天通知用户:" D
sed -i '/^PASS_MAX_DAYS/cPASS_MAX_DAYS '$A'' /etc/login.defs
sed -i '/^PASS_MIN_DAYS/cPASS_MIN_DAYS '$B'' /etc/login.defs
sed -i '/^PASS_MIN_LEN/cPASS_MIN_LEN '$C'' /etc/login.defs
sed -i '/^PASS_WARN_AGE/cPASS_WARN_AGE '$D'' /etc/login.defs
echo "已对密码进行加固,新用户不得和旧密码相同,且新密码必须同时包含数字、小写字母,大写字母!!"
sed -i '/pam_pwquality.so/cpassword requisite pam_pwquality.so try_first_pass local_users_only retry=3 authtok_type= difok=1 minlen=8 ucredit=-1 lcredit=-1 dcredit=-1' /etc/pam.d/system-auth
echo "已对密码进行加固,如果输入错误密码超过3次,则锁定账户!!"
n=`cat /etc/pam.d/sshd | grep "auth required pam_tally2.so "|wc -l`
sed -i '/%PAM-1.0/aauth required pam_tally2.so deny=3 unlock_time=150 even_deny_root root_unlock_time300' /etc/pam.d/sshd
fi
echo  "已设置禁止root用户远程登录!!"
sed -i '/PermitRootLogin/cPermitRootLogin no'  /etc/ssh/sshd_config
read -p "设置历史命令保存条数:" E
read -p "设置账户自动注销时间:" F
sed -i '/^HISTSIZE/cHISTSIZE='$E'' /etc/profile
sed -i '/^HISTSIZE/aTMOUT='$F'' /etc/profile
echo "已设置只允许wheel组的用户可以使用su命令切换到root用户!"
sed -i '/pam_wheel.so use_uid/cauth required pam_wheel.so use_uid ' /etc/pam.d/su
n=`cat /etc/login.defs | grep SU_WHEEL_ONLY | wc -l`
echo SU_WHEEL_ONLY yes >> /etc/login.defs
fi
echo "即将对系统中的账户进行检查...."
echo "系统中有登录权限的用户有:"
awk -F: '($7=="/bin/bash"){print $1}' /etc/passwd
echo "********************************************"
echo "系统中UID=0的用户有:"
awk -F: '($3=="0"){print $1}' /etc/passwd
N=`awk -F: '($2==""){print $1}' /etc/shadow|wc -l`
echo "系统中空密码用户有:$N"
if [ $N -eq 0 ];then
 echo "恭喜你,系统中无空密码用户!!"
else
 i=1
 while [ $N -gt 0 ]
 do
    None=`awk -F: '($2==""){print $1}' /etc/shadow|awk 'NR=='$i'{print}'`
    echo "------------------------"
    echo $None
    echo "必须为空用户设置密码!!"
    passwd $None
    let N--
 done
 M=`awk -F: '($2==""){print $1}' /etc/shadow|wc -l`
 if [ $M -eq 0 ];then
  echo "恭喜,系统中已经没有空密码用户了!"
 else
echo "系统中还存在空密码用户:$M"
 fi
fi
echo "即将对系统中重要文件进行锁定,锁定后将无法添加删除用户和组"
read -p "警告:此脚本运行后将无法添加删除用户和组!!确定输入Y,取消输入N;Y/N:" i
case $i in
      [Y,y])
            chattr +i /etc/passwd
            chattr +i /etc/shadow
            chattr +i /etc/group
            chattr +i /etc/gshadow
            echo "锁定成功!"
      [N,n])
            chattr -i /etc/passwd
            chattr -i /etc/shadow
            chattr -i /etc/group
            chattr -i /etc/gshadow
            echo "取消锁定成功!!"
            echo "请输入Y/y or N/n"
esac
PID
五、实现磁盘分区的
只支持分配主分区和标准的linux文件系统(ext4/xfs)的分区
#! /bin/bash
# Function:对硬盘进行分区,得到一个标准的linux文件系统(ext4/xfs)的主分区
cat /proc/partitions > old
read -p "请输入你要分区的硬盘(写绝对路径,如:/dev/sda):" A
if [ -e $A ];then
  echo "true"
else
  echo "该设备不存在!!"
  exit
fi
read -p "请输入你要创建的磁盘分区类型(这里只能是主分区,默认按回车即可):" B
read -p "请输入分区数字,范围1-4,默认从1开始,默认按回车即可:" C
read -p "请输入扇区起始表号,默认按回车即可:" D
read -p "请输入你要分区的分区大小(格式:如 +5G ):" E
fdisk $A << EOF
n
p
$C
$D
$E
w
EOF
echo "一个标准的linux文件系统的分区已经建立好!!"
partprobe $A
echo "-------------------------------"
cat /proc/partitions > new
F=`diff new old | grep "<" | awk '{print $5}'`
echo $F
echo "你想对新分区设定什么类型的文件系统?有以下选项:"
echo "A:ext4文件系统"
echo "B:xfs文件系统"
read -p "请输入你的选择:" G
case $G in
        a|A)
           mkfs.ext4 /dev/$F
           echo "该分区将被挂载在 "/mnt/$F" 下"
           m=`ls /mnt/|grep $F | wc -l`
           if [ $m -eq 0 ];then
            mkdir /mnt/$F
           fi
           n=`cat /etc/fstab | grep /dev/$F| wc -l`
              echo "/dev/$F     /mnt/$F     ext4         defaults          0      0" >> /etc/fstab
           else
              sed -i '/^/dev/$F/c/dev/$F     /mnt/$F     ext4         defaults          0      0' /etc/fstab
           fi
           mount -a
           df -Th
        b|B)
           mkfs.xfs -f /dev/$F
              mkdir /mnt/$F
           fi
           n=`cat /etc/fstab | grep /dev/$F | wc -l`
              echo "/dev/$F     /mnt/$F      xfs       defaults          0      0" >> /etc/fstab
           else
              sed -i '/^/dev/$F/c/dev/$F     /mnt/$F     xfs         defaults          0      0' /etc/fstab
           fi
           mount -a
           df -Th
           echo "你的输入有误!!"
esac
六、使用一整块硬盘创建逻辑卷
#!/bin/bash
# Function:使用一整块硬盘创建LVM逻辑卷
read -p "请输入你要做成逻辑卷的硬盘(写绝对路径,如:/dev/sda):" path
if [ -e $path ];then
  echo "true"
else
  echo "该设备不存在!!"
  exit
fi
pvcreate $path
echo "该硬盘已做成物理卷!"
vgcreate myvg $path
echo "该物理卷已加入卷组 myvg 中"
vgs
free=`vgs| awk '$1~/myvg/{print}'|awk '{print $6}'`
echo "该物理卷剩余的空间大小为:$free "
read -p "请输入你要创建逻辑卷的大小(如:1G):" repy2
lvcreate -L $repy2 -n mylv myvg
echo "已成功创建逻辑卷mylv"
lvs
echo "A:ext4文件系统"
echo "B:xfs文件系统"
read -p "请输入你的选择:" repy3
case $repy3 in
        a|A)
           mkfs.ext4 /dev/myvg/mylv
           echo "该分区将被挂载在 "/mnt/mylv" 下"
           m=`ls /mnt/|grep mylv | wc -l`
            mkdir /mnt/mylv
           fi
           echo "/dev/myvg/mylv     /mnt/mylv     ext4         defaults          0      0" >> /etc/fstab
           mount -a
           df -Th
        b|B)
           mkfs.xfs -f /dev/myvg/mylv
              mkdir /mnt/mylv
           fi
           echo "/dev/myvg/mylv     /mnt/mylv      xfs       defaults          0      0" >> /etc/fstab
           mount -a
           df -Th
           echo "你的输入有误!!"
esac
七、将一块硬盘分区,然后分区设置为虚拟卷
#! /bin/bash
# Author:谢公子
# Date:2018-10-13
# Function:新建一个分区,并做成逻辑卷
if [ -e $A ];then
  echo "true"
else
  echo "该设备不存在!!"
  exit
fi
read -p "请输入你要划分为逻辑卷的分区盘符(默认回车即可):" Z
fdisk $A << EOF
n
p
$C
$D
$E
t
$Z
8e
p
w
EOF
echo "一个标准LVM的分区已经建立好!!"
partprobe $A
echo $F
pvcreate /dev/$F
echo "该硬盘已做成物理卷!"
n=`vgs | grep myvg |wc -l`
   vgcreate myvg /dev/$F
   echo "该物理卷已加入卷组myvg中"
else
   vgextend myvg /dev/$F
   vgs
   free=`vgs| awk '$1~/myvg/{print}'|awk '{print $7}'`
   echo "该卷组剩余的空间大小为:$free "
   lvs
   exit
fi
vgs
echo "已成功创建逻辑卷mylv"
lvs
echo "A:ext4文件系统"
echo "B:xfs文件系统"
case $G in
        a|A)
            mkdir /mnt/$F
           fi
           echo "/dev/myvg/mylv     /mnt/$F     ext4         defaults          0      0" >> /etc/fstab
           mount -a
           df -Th
        b|B)
              mkdir /mnt/$F
           fi
           echo "/dev/myvg/mylv     /mnt/$F      xfs       defaults          0      0" >> /etc/fstab
           mount -a
           df -Th
           echo "你的输入有误!!"
esac
  审核编辑:汤梓红
