上一期介绍了使用量化软件BDF进行Ir(ppy)₃的基态S0的结构优化和频率计算。这一期将介绍第一激发三重态T1的结构优化和频率计算的过程。
Irppy3_t1.xyz内容如下:
准备Ir(ppy)₃分子结构的xyz文件如下:
61
Ir -0.00021963 0.00084588 0.01424181
C 2.59517396 -1.31710199 -0.58086411
C 2.23709967 0.40664133 -2.11684705
C 3.82729349 -1.60375453 -1.18851600
C 2.03843393 -2.01080680 0.57861773
C 3.44334868 0.17103124 -2.75937571
H 1.56522101 1.20579483 -2.43942631
C 4.25160770 -0.86138490 -2.27959559
H 4.44860577 -2.40719663 -0.79331056
C 2.69382363 -3.08153995 1.20802708
H 3.74085930 0.78654308 -3.60925966
H 5.21146469 -1.08097154 -2.75293386
C 0.24421139 -2.16970311 2.17811922
C 2.12763720 -3.69300459 2.31682204
H 3.65478554 -3.44259873 0.83261331
C 0.89831764 -3.22978876 2.79882363
H -0.71249803 -1.82386403 2.57651491
H 2.63779958 -4.52517522 2.80699129
H 0.44660698 -3.70582388 3.67403286
C -1.72035469 0.07933387 1.04722001
C -2.76313413 -0.76101290 0.56881686
C -2.01025266 0.87257612 2.17113445
C -4.02037491 -0.79383502 1.19368759
C -2.43582629 -1.59048558 -0.58889316
C -3.25751526 0.83538180 2.78746398
H -1.23410642 1.52839366 2.57249446
C -4.27126073 0.00210869 2.30157161
H -4.81180920 -1.44586060 0.81528272
C -3.29617560 -2.51740929 -1.19724703
H -3.44731484 1.46422538 3.66217358
H -5.24881003 -0.02406750 2.78811438
C -0.75837785 -2.14128396 -2.11906742
C -2.86048279 -3.25738595 -2.28544733
H -4.30328496 -2.65589425 -0.80436165
C -1.56140370 -3.07140479 -2.76199645
H 0.27022263 -1.95736074 -2.43892538
H -3.52729093 -3.98185076 -2.75888376
H -1.17316801 -3.63790053 -3.60937499
N -1.18202102 -1.42059810 -1.07683756
C -0.15520348 2.90563657 -0.58971088
C -1.46338895 1.72871866 -2.12679953
C -0.52211987 4.11414752 -1.20165791
C 0.72001848 2.77388462 0.57312738
C -1.86121725 2.88919512 -2.77366419
H -1.81791319 0.74611096 -2.44764729
C -1.37377275 4.10694585 -2.29536844
H -0.13934280 5.05543436 -0.80755998
C 0.92315032 1.45037015 1.05224777
C 1.31701199 3.87857243 1.20194236
H -2.54044030 2.83638038 -3.62545723
H -1.66304625 5.04659184 -2.77183207
C 1.74847348 1.30397901 2.18095829
C 2.12513377 3.69714085 2.31457434
H 1.15050564 4.89023888 0.82308669
C 2.33662182 2.40226678 2.80117156
H 1.92559465 0.30363467 2.58285826
H 2.58863363 4.55643063 2.80428368
H 2.97087444 2.25159426 3.67958431
N -0.63391888 1.73510439 -1.07938881
N 1.82331270 -0.31615001 -1.07209969
C 0.78888390 -1.52564414 1.05342887
选择Simulator → BDF → BDF,在界面中设置参数。在Basic Settings界面中的Calculation Type选择TDDFT-OPT+Freq,方法采用默认的PBE0泛函,基组在Basis中的All Electron类型中,选择Def2-SVP。Basic Settings界面中的其它参数使用推荐的默认值,不需要做修改。
SCF Settings界面中将Use MPEC+COSX Acceleraton的默认勾选去掉。SCF Settings界面中的其它参数使用推荐的默认值,不需要做修改。
TDDFT Settings面板中将Use MPEC+COSX Acceleraton的默认勾选去掉。Mutiplicity选择Triplet,Convergence Threshold选择Very Tight。TDDFT Settings界面中的其它参数使用推荐的默认值,不需要做修改。
OPT Settings和Freq Settings面板的参数使用推荐的默认值,不需要做修改。之后点击 Generate files 即可生成对应计算的输入文件。选中生成的bdf.inp文件,右击选择open containing folder进入所在文件夹,在bdf.inp的$tddft模块中加入:
Gridtol
1E-6
bdf.inp内容如下:
$compass
Title
C33H24IrN3
Geometry
End Geometry
Basis
Def2-SVP
Skeleton
Group
C(1)
$end
$bdfopt
Solver
1
MaxCycle
366
IOpt
3
Hess
final
$end
$xuanyuan
Direct
$end
$scf
RKS
Charge
SpinMulti
1
DFT
PBE0
D3
Molden
$end
$tddft
Imethod
1
Isf
1
Ialda
4
Idiag
1
crit_e
1E-9
crit_vec
1E-7
Gridtol
1E-6
Iroot
6
Istore
1
$end
$resp
Geom
Method
2
Nfiles
1
Iroot
1
$end
选中bdf.inp文件,右击选择Run提交作业,任务结束后bdf.out,bdf.out.tmp,bdf.scf.molden三个结果文件会出现在Project中。
选择bdf.out,右击show view,在Optimization对话框中,显示结构已经达到收敛标准。
在Frequency对话框中,检查频率,若不存在虚频证明结构已经优化到极小点。
选择bdf.out文件,右击open with containing folder打开bdf.out文件,在文件中查找‘converged in’,紧接着输出的‘Molecular Cartesian Coordinates (X,Y,Z) in Angstrom : ’下的结构即为优化好的T1激发态的结构。将其保存为Irppy3_t1_soc.xyz文件,如下:
61
Ir 0.00713728 0.02772384 0.06844143
C 2.49525480 -1.44901550 -0.61634342
C 2.18832036 0.30085414 -2.14613716
C 3.68634391 -1.80881598 -1.26572189
C 1.93194560 -2.11689508 0.55823360
C 3.35838993 -0.00562745 -2.82371008
H 1.54555778 1.13535499 -2.43828057
C 4.11644204 -1.08671357 -2.36826138
H 4.27131595 -2.65056635 -0.89578008
C 2.53568350 -3.23676194 1.15281696
H 3.66807720 0.59265321 -3.68133338
H 5.04582829 -1.36185464 -2.87261245
C 0.15985754 -2.20796739 2.19060975
C 1.95468524 -3.83725789 2.26057143
H 3.46642195 -3.64596143 0.75209976
C 0.76249168 -3.31842903 2.77624738
H -0.76777546 -1.81381956 2.61329026
H 2.42616559 -4.70662836 2.72403491
H 0.30108846 -3.78788395 3.64972556
C -1.72817262 0.21988877 1.05055833
C -2.80684294 -0.57231379 0.57552059
C -1.98377974 1.07446425 2.13652018
C -4.07348284 -0.50293868 1.17614116
C -2.51722058 -1.44616477 -0.55935718
C -3.24105830 1.13344573 2.72846833
H -1.17254968 1.69178400 2.52835606
C -4.29332764 0.34509124 2.25152759
H -4.89835192 -1.11318656 0.80076906
C -3.42583031 -2.33456216 -1.15446766
H -3.40666531 1.80444609 3.57586126
H -5.27935386 0.39610056 2.71819787
C -0.85701735 -2.13799807 -2.04878703
C -3.02057249 -3.12865177 -2.21547404
H -4.44525951 -2.39959512 -0.77498376
C -1.70631730 -3.03592702 -2.67708276
H 0.18295061 -2.02278722 -2.36320871
H -3.72428268 -3.82273458 -2.68079360
H -1.34337957 -3.64618311 -3.50492143
N -1.25281509 -1.36491844 -1.03498749
C 0.05749757 2.91146589 -0.57266019
C -1.32777267 1.80183369 -2.13392316
C -0.20378718 4.13789922 -1.23242993
C 0.84833732 2.74053836 0.60027468
C -1.62207961 2.97568834 -2.79963589
H -1.76529075 0.85235254 -2.45705604
C -1.02279372 4.18710974 -2.33345871
H 0.25619858 5.05119986 -0.85064151
C 0.99228869 1.37116718 1.10523883
C 1.50408647 3.78492492 1.29091761
H -2.29824567 2.96275979 -3.65460398
H -1.21968527 5.13470890 -2.83803374
C 1.79964051 1.14876808 2.23660071
C 2.27478596 3.51131149 2.40946143
H 1.40861651 4.81693356 0.94742301
C 2.43450283 2.19478112 2.89597173
H 1.90681895 0.12796182 2.60984200
H 2.77105979 4.33756352 2.92655136
H 3.04508360 2.00761950 3.78145403
N -0.50508694 1.73366277 -1.08285478
N 1.77567220 -0.40171722 -1.08777429
C 0.72548984 -1.57229627 1.07484739
下一期将介绍使用BDF软件基于T1激发态结构,做S0和T1之间的旋轨耦合SOC计算,以及基于BDF的量化计算结果,使用MOMAP软件进行Ir(ppy)3的磷光辐射速率计算的过程。
编辑:黄飞
